Wierd Problem???
  • Thread starter Thread starter stevek
  • Start date Start date
S
stevek
I have been using my standard sky dish and pace 2200 digibox and all as well until this month when i started having a bad picture and some channels saying there is no signal. I can recieve channel 4, sky news, and sometimes bbc choice but then sometimes all the other channels are ok as well (but not for long.
My Signal Strength is 3/4 and so is the quality. Whats wrong lads, any help on this would be great as i think i may chuck this box out the window soon.
Steve k
There have been problems with the software in some of the older boxes Steve, had similar problems last week with an old Grundig, but a reset cleared the problem for a while. It doesn't sound like a dish problem, but to double check, why not see if you can try your box on a friend's dish and your friend's box on your dish.
