2.4 DH Antenna installation
It's looking good.
I noticed that some of the rail tracks seem to have new cuts at the ends, did you cut them yourself?
It would have taken a good saw or grinding wheel to cut through that amount of steel.
Rgds
Thanks happy someone else likes it as well as me :), no I had it cut to the size I wanted it, you need special blades and chop saw to cut it properly/easy, cost me a extra £30 for cuts, I wasn't prepared to buy a saw drill was enough
2
Yes, my local metal stockholder had to import the blades from the USA for his big metal saw, it was high cost just for the blades. The saw he had was like a huge mechanical hacksaw with blades almost 1 metre long, just load the steel into the saw, position and clamp it for the cut and press the button.
Will we see pics of the dish on the rails today, you must be getting close to getting the dish erected?
Rgds
2
Rgds
Its hard steel, sounds like he's using a band saw,
Unfortunately its been raining all morning and got nothing done, decided just to strap it on while after inspection, I need to do more rail drilling to bolt king post, a few more pictures
I need to hit the above gap in houses to stand a chance of 65.5E, now I'm using prime focus I stand more of a chance dish pointing directly at the satellite less obstacles time will tell :)
Birds will be happy, plenty food for them on the rail track today :)
It's just my opinion but I think the prime focus dishes are a lot easier to line up on the arc compared to offset dishes.
Rgds
Rgds
Like watching the birds, this time of year its nice to help them along the way. I get mouse at night well I get a few don't mind mouse, rat I don't want
Agree 100% :), prime focus better if you have obstacle will increase arc from offset,
I need to paint dish green, get washed dish down and first inspection, dish is in very good condition rim is how it should be, just one small dent half size of a pea, very pleased with condition,
Will string dish make sure its perfect shape when I service motor and other parts.
Same for me with the birds, as you say, they can do with a bit of help in the cold winter weather. We have 3 x sunflower feeders, 2 x niger seed feeders for the Goldfinches, two fat ball feeders, fat slab feeder, peanut feeder and I throw a half litre container of bird seed on the ground every morning. The Chaffinches seem to prefer the seeds from the ground.
Do you have to paint the dish green, is it part of your planning approval? It seems a shame to have to paint over such a nice dish. The white powder coating or white paint would probably restore very nicely if it was an option.
Rgds
:), I don't get many ground feeding birds the goldfinch pop down sometimes, robin, dunnock, blackbird, doves, pigeon sometimes I get town pigeon, mainly feed sunflower and niger seeds
I guess I don't have to its on wheels can leave it as it is do what I want, but quite sure some neighbour's would appreciate it green, don't want to upset anyone more than necessary
Nice double adjustment system.
Will we get pics of the dish on the mount today, you must be getting close to fitting the dish?
Rgds
Thanks, It was installed for inspection back down now for refurbishment, will posts pictures on final installation, found a stamp on dish, will contact DH for information
H to H serviced, it has a grease nipple still had to take it apart, very simple but effective design, need to clean the outside down now
Dish now ready for final installation, still a few things to do but nothing stopping dish going up,
One of the threads snapped on arms, could be a problem, metal and aluminium oxidise can be very stubborn, will weld nut on and get some heat on aluminium hope it loosens up, will make new arms if not
One of the threads snapped on arms, could be a problem, metal and aluminium oxidise can be very stubborn...
It's also a common problem with old Precision dishes, the bolts can get locked into the arms where the arms secure to the dish face. Also, the threaded studs at the feed end of the arms are often locked on old Precision dishes.
I have used a flame from a small butane gas cannister type of blowtorch to free them up. The aluminium expands easily and I have found its sometimes the only way to free them up, especially if you need things sorted out quickly and cannot wait for days/weeks to soak the parts in releasing fluid. A 50-50 mix of acetone and ATF (automatic transmission fluid) makes a very good mixture for soaking if you have the time.
You are almost there, hopefully there will be some pics of the dish installed and some signal captures in the next day or two. You should get some nice C Band catches with that dish, its a real nice dish.
Rgds
Rgds
Same with this threaded rod at each end of arm x 3, I need them all free, have to see how the first one goes, if its a pain will be quicker to make new ones, I have oxy acetylene torch to apply heat but its not guaranteed to do anything,
Thanks for the soaking tip :),
Long way to go to get setup how I want it, need to modify mount for declination control Eprom upgrade four port feed horn run cables more fixing on stand make platform to accept paving slaps on movable base more painting string dish etc, will test drive it before all this though :),
Thanks it is a nice dish very pleased with it :)
Until the main compounds in petrol were changed a few years ago (less volatiles) a 50/50 mix with diesel was a good soaking agent. I haven't tried the new stuff but somebody might have.
One job to cross of the list
Next job is to make sure I have enough weight on platform, looking at the spec 100mph wind @ 60° will create a force of 2400 pounds 1.08862 Tonne (ton)
2.4-3.3m | DH Satellite
Estimating not that far away from this but going to add more weight in each corner, then happy for dish to go up, it will also be strapped to runway, it wont be going anywhere
Looks like the MAG drill has been working again on the holes for the levelling system on the stand. :)
What size eye bolts are you using for the levelling system, are they M12?
Thx
Thx
Its a dam good drill having a magnet drill is great for something like this, M16 eye bolts
Found NPRM in workshop ideal, have 450x450 paving from patio, will put five in each corner, that will give me extra 0.33 Tonne (ton)
Need to install winch for moving base up/down runway base then finished
