Had a bit of a disaster this week
gap30
technomate 90cm dish
Liverpool
Decided to upgrade my dish this week with not good results
Previously had a technomate 90cm dish with tm2300 motor and it worked fine 28.2, 16, 13, 0.8, 30w etc
Bought a second hand gibby op125, new stab HH120 motor, gibby feedhorn, invacom c120 LNB
Spent the last 3 days messing around with it and i am not a happy bunny to put it mildly
So i did exactly what i did with my previous dish, go to Thor 0.8w and tune to BBC World News (75% SNR)
But no signal on any other satellite, my heavy duty L bracket is bang level
This was supposed to be an upgrade and has been a disaster
I am not a satellite engineer and have limited tools ie crappy meter off ebay
My thinking was i set the last one up so this should be straight forward
Now some things that may or may not be causing me problems
I have had to fit an additional back plate to the dish to stop it hitting the motor so am not sure if that could cause problems
I have removed the rod which allows you to fine tune the dish from behind as this would hit the motor as the dish turned
I know most people dont have time for people like me but my sanity has been pushed this week
Trust me i have 75% snr on Thor and nothing else, any suggestions (apart from scrap the dish lol)
blademedia
Sky
Can you post some pictures, its possible to install the mount upside down with this dish
gap30
Liverpool
Been there trying to aim a dish a at satellite the size of a small caravan 22,000+ miles away:eek:
It is probably one of these:-
1/ Pole must be dead vertical in 360 degrees ( use a spirit level ),
2/ Dish mounted dead central on the motor spigot,
3/ Motor set at the correct Elevation for your location for maximum signal at your reference satellite,
4/ Motor at zero on the scale when aimed at your reference satellite,
5/ Dish Declination set for maximum signal at your reference satellite,
6/ Lnb set in the correct position for max signal(Move Lnb fully forward & Back while viewing a meter for max signals)
That is why it is best to upgrade in the spring /summer months anyway this may help you.
  • Setting up a Motorised system to pull in weak signals for improved Satellite TV reception.zip
Hixxy1
East Midlands
Sounds like the elevation on the motor bracket is off.
Sent from my Nokia 3310 using Tapatalk
Based on the "fact" (?) that the pole has not been touched it sounds like 2), 4) or 5) as the rest of would probably still result in reception of some adjacent strong signal satellites - 2) or 4) because that would mean that the arc is way off for anything other than Thor or else 5) because the declination is very critical as I know from my experiences with both my steerable and fixed dishes in Spring last year.
gap30
Liverpool
My latitude is 53.461 and longtitude is 002.965
My dish elevation is 22.4
This gives me a very strong signal on Thor but i am doing something wrong somewhere
dxhound2003
Az Box Premium.
Triax 110 cm dish motorised.
Black Ultra LNB. Nov 2011 DrD F15.
Dundalk Ireland
I thought BBC World News was gone from Thor. What transponder is it on? You should certainly be able to get Sky News on Thor, 12418 V 28000. 17.2 dB signal in Ireland 1.1 m dish.
If that is correct for your dish at your latitude at your location (I don't know), then that would probably leave 2) or 4).
Latest post now deleted
sonnetpete
wordpress.com
Normandy, France
Basically you've gone from a fairly lightweight setup to something quite a bit heavier and hung it all on the end of an ''L' bracket. I'd recheck your mount for alignment and not just with a spirit level. Try and find a digital angle finder and get it to within 0.2 of a degree. With the heavier dish and motor combination you have now, I would also recommend a T&K wall mount.
Are you saying it might not be well hung?
gap30
Liverpool
That is probably the right answer, thing is front of my house is south facing
I live in a terraced house with a back yard, my tv is at the front of the house and i worry about the length of the cable run
dxhound2003
Az Box Premium.
Dundalk Ireland
11403 V is 13 dB signal with me. BBC World News is encrypted there. The previous FTA version which used to be the reference signal for 1 West is gone. I think the Sky News transponder is the strongest one these days.
sonnetpete
wordpress.com
Normandy, France
Don't see how changing the bracket will alter the cable length. You shouldn't need a set of T&K's with an excessive offset and in any case that would only add a few centimetres to the cable run....decent quality cable should negate any worries about how long the cable run is...
Mickha
North West
You list your location as Liverpool, which according to dishpointer pute you latitude about 53.4, and more importantly your longitude as -2.99, this is very important.
Negative Longitude readings = West, positive = East, so if using USALS, to drive your motor, you need to enter the correct settings, then drive your motor, and dish, to the satellite you have selected to align your dish, in your case 0.8W.
You then physically move the dish, and motor, to get the strongest signal on 0.8W, use the dish elevation as a guide, as they aren't always accurate.
Once aligned to 0.8W tighten everything up and send the dish, using your receiver, to various satellites, East, and West, to check your signal quality.
You then send it back to 0.8W, to make minor adjustments, to get it tracking the satellite arc correctly.
blademedia
Sky
From memory stabs motor are double marked, also gib elevation is, you must use the correct setting on motor and dish
gap30
Liverpool
Sorry i should have described it better, i would only put a pole up at the back which would add about 15m to the run
here is a pic of my old dish on the front of my house:
