- May 29, 2009
- North York Moors
So ..... will it fit?
No I only have 47" to play with ;)So ..... will it fit?
So I've been told ..Drat.
So size is important, after all
We heard a rumour, Rachael mentioned itSo I've been told ..
..all too often..
Oh ..so you've been seeing her behind my back ..We heard a rumour, Rachael mentioned it
I think there is something that allows you to expect the product to last a curtain amount of time.
I think you may have drawn the wrong conclusion there, the company will be looking for a net profit....
This is what I meant
3D is dead.I ignored the rather stoopid transition to 3D ..
LOL Chris :I was making a pun out of "a curtain amount of time"....
Have you finished it yet? ;)
You can order a smart remote as a extra for the 650v
Cheeky gurlz ??The curtain only needs to be 47 inches wide, which will save some fabric for a short skirt , or two .
