Intelsat 33E & Intelsat 36 from august
On 19 Dec, Intelsat tweeted the in-orbit testing of Intelsat 33e had begun.
Now on 12102 V and 12172 V.
In my area those two have very strong signal:
Intelsat 33e left 59.55°E, now 59.85°, moving towards 60°E. Still with test signals 12102 V and 12172 V.
mar-val
Slovakia,Zilina
First TPs , verticals are pretty weak.o_O
shawl_who
SES7, Yahsat 1A, Yamal 54.9e, express am33 @103e, eutelsat 36b
New Delhi, India
any one have the actual footprints ?
The ku beam, shown on intelsat's site, shows cluttered eurasian n spot beams... its unclear, which places are covered.
11490 H
DVB-S/MPEG-2 3700 3/4
Kuban 24
TRBNA
11498 H
DVB-S2/8PSK
MPEG-4 7270 9/10
11503 V
DVB-S/MPEG-2 3330 3/4
Life78
Nika TV (Kaluga)
11521 V
In my area the signal on Vert. pol is not weak. It remained at the same level as before,meaning strong.Only 11503 V is really very weak.
On 10960 H we have a test carrier.
Edited:Sorry,trps. with strong signal on vertical are on Intelsat 904!
satkingdom
Turkey
10 fixed offset antennas ranging from 107 cm to 170 cm with multifeed systems on them.
Next Machina3D Satellite Receiver
North-East of Turkey
I can get very strong signal from 11490 H 3700 and 11.498 H 7270. Vertical signals 11.503 V 3330 (without freezing) and 11.521 V 3700 (freezing) are very weak from the North-east of Turkey. The former two and the latter two may be on different beams.
Makes much sense!
Spot 34 (South European Russia): 11490 H = Krasnodar (Kuban24), 11498 H = Armenia
Spot 40 (North European Russia): 11503 V = St.Petersburg (L!fe78), 11521 V = Kaluga (Nika TV).
blademedia
Sky
Very surprisingly I'm getting a signal from 11498, 1.2 dish its very weak well below lock but encouraging to try a bigger dish here, I get nothing on the V transponders.
mar-val
Slovakia,Zilina
For mode 8PSK 9/10 , you need 11db, in your case it is ca 4m dish...:eek:
blademedia
Sky
I cant understand why I cant see 11490 H 3/4 fec can we be sure 11490 and 11498 is on the same beam ?
blademedia
Sky
Ive had signal up to 4.8 db, checking now signal in the -
Intelsat 33e (60°E), freq. 11,077 GHz, pol. V, SR 8332, FEC 5/6, DVB-S2/8PSK, FTA
Bulgaria start
Thread closed as both birds are now in service. I'll try & tidy it up a bit over the next few days to split posts off into the appropriate reception threads
