Newbie Here How do I set this up?
NatKarmios
Inverto Unicable II LNB (IDLU-32UL40-UNBOO-OPP)
Vu+ Solo 4K
Greater London
Hey everyone, my dad just bought a sattelite setup, and needs my help setting things up. I have Linux experience, however I have never dabbled in sattelite TV before.
We're using a Vu+ Solo 4K, connected straight to a Inverto Unicable II LNB (IDLU-32UL40-UNBOO-OPP) via the LNB 2 port.
We've been trying to get it working for a while, to no avail.
The LNB is successfully recieving ~13V, and is pointed in the correct direction.
All I've done with the Vu+ box (besides fruitlessly messing with the tuner options) is install the latest version of Black Hole over the default software.
Any help is appreciated!
sonic1
Vu + Ultimo 4K - Solo 4K - Uno 4K - Duo2- SoloSE - Zero- Uno -Prismcube Open Black Hole - 0.6 , 98cm Funkee , 28E-23.5E-19E-13E
Black Hole Team
What exactly does not work ?
Nothing FTA ?
Elaborate a little please.
Welcome to the Forum.
Have you installed and aligned the dish yourself?
How do you know it's correctly aligned? ("Pointing in the right direction" isn't meaningful without evidence to back it up!)
NatKarmios
Vu+ Solo 4K
Greater London
My father used a Labgear Sattelite Finder to confirm the alignment.
NatKarmios
Vu+ Solo 4K
Greater London
Nothing FTA ?
Well, I'm just not sure how to set the receiver to actually watch TV from the satellites.
sonic1
Black Hole Team
You have Black Hole Image on the box, as long as you have managed to get the box on your home network you can download channel settings via the addons. Green Button > Yellow Button.
Once you have installed the settings you can see if you have set up the tuner configuration and aligned your dish correctly.
pgh13
Midlands UK
What satellite are you trying to 'find?' That's not a trick question; there are many satellites and a good indication on a satellite finder doesn't identify which one you're pointing at.
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
I do not have an up to date version however this shows the satellites on the Clarke Curve viewable from the UK, some years ago, easy to think you are on one but it is anothersatarc.jpg
NatKarmios
Vu+ Solo 4K
Greater London
I'm not quite sure how this is done, I don't see anything in the "addons" menu that looks like it relates to this.
NatKarmios
Vu+ Solo 4K
Greater London
We want to connect to Astra 28.2E, and we've aligned it as such.
Does receiver need special setup for a Unicable LNB?
Mickha
North West
It's not that easy to align a satellite dish to Astra 2, 28.2E, unless you've done it before.
All a cheap satellite meter will tell you is that your dish is picking up a signal, and allow you to fine tune the dish, providing you use it correctly.
Can you please tell us how you aligned the dish? Have you aligned a satellite dish before?
You state that you are using Tuner B, on your VU+ Solo 4K, is this correct?
Have you tried scanning in any other satellites, in case you are aligned to 23.5E, 19.2E, or a different satellite?
If possible try setting your receiver up on a different dish, a friends, neighbors, or relatives, that you know is aligned to 28.2E, and scan in some channels.
John Pykett
Persona non grata
Dish setup: 80cm Motorized Dish, TM-5402 HD M3. This setup goes from 1w to 28.2e
My computer setup: AMD Athlon II X4 645 3.10 GHz processor and 8GB of ram. Graphics Card is NVIDIA GTX 750 Ti. OS: Windows 10 64 Bit
Hucknall, United Kingdom
a satellite finder only shows you that you have a signal but it does not show you what satellite you are locked onto
Did you read the post just above yours before posting this?
Tururu
Assembled with recycled parts
Recycled as the owner.
As you do not indicate that knowledge to adjust the parabolic antenna you have, flip the subject.
But we did not read, first thing, you bought the programmed LNB already or not.
The question is strange, but it is very important, that LNB is programmable and the programmer is very expensive.
Confirm with the store where you bought the LNB this point, it is very important, if by default brings the configuration that is indicated in the web of inverted, we can continue, but if it is not configured, it is a problem.
When you confirm this point we continue.
For companions, with this LNB are not worth the satfinder, pitofonos and/or field meters normal.
Como no indicas que conocimientos para ajustar la antena parabolica tienes, jodio el tema.
Pero no nos liemos, lo primero, compraste el LNB programado ya o no.?
La pregunta es rara, pero tiene mucha importancia, ese LNB es programable y el programador vale muy caro.
Confirma con la tienda donde compraste el LNB este punto, es muy importante, si por defecto trae la configuracion que se indica en la web de inverto, podemos continuar, pero si no esta configurado, es un problema.
Cuando confirmes este punto continuamos.
Para los compañeros, con este LNB no valen los satfinder, pitofonos y/o medidores de campo normales.
Tururu
With that LNB, that is not possible.
You would have a normal LNB, he confirms.
The tuner to adjust the antenna / LNB you can use a normal LNB without problems, already adjusted the antenna, you change the LNB by the unicable and ready.
Do not forget to ask in the store if the LNB has the manufacturer's website programming.
In Madrid consult and had to ask for it programmed, implying that it came without programming, the programmer is worth more than 200€uros.
Con ese LNB, eso no es posible.
Tendrias puesto un LNB normal, confirma.
El sintonizador para ajustar la antena/LNB puedes utilizar un LNB normal sin problemas, ya ajustada la antena, cambias el LNB por el unicable y listo.
No olvides preguntar en la tieneda si el LNB tiene la programacion de la web del fabricante inverto.
En Madrid consulte y tenia que pedirlo programado, dando a entender que venia sin programar, el programador vale mas de 200€uros.
Si tienes dudas y lo puedes cambiar, pide el modelo/If you have doubts and you can change it, ask the model...40€ mas portes.
Megasat Diavolo Unicable 2 SCR LNB Einkabel HDTV 0,1dB bis 24 Teilnehmer
To configure the receiver you have (VU + Solo4K image Openspa similar BH) with normal LNB, this is the configuration.
Change Astra a 19'2ºE ==> Astra a 28'2ºE...OK
Tuner B, configured as a loop/connected to Tuner A.
The others are left in automatic, important.
Para configurar el receptor que tienes (VU+Solo4K imagen Openspa similar BH) con LNB normal, esta es la configuracion.
Cambia Astra a 19'2ºE ==> Astra a 28'2ºE...OK
El Tuner B, configurado como bucle/conectado al Tuner A.
Los demas se dejan en automatico, importante.
Tururu
Cuando tengas la antena/LNB bien ajustada al satelite Astra a 28'2ºE, esta es la configuracion unicable, es para Astra a 19'2E, cambia el satelite al Astra a 28'2ºE y tema solucionado, resto igual.
When you have the antenna / LNB well adjusted to the Astra satellite at 28'2ºE, this is the unicable configuration, solved, rest the same.
Unicable II programmable 40mm LNB with 32UB: IDLU-32UL40-UNBOO-OPP
Recuerda cambiar el modelo de LNB unicable.
Pica en especificaciones, similares en el que indico de Megasat
Remember to change the unicable LNB model.
Pica in specifications, similar in that I indicate of Megasat
Inverto - IDLU-32UL40-UNBOO-OPP -
Chopping in the photos are magnified/Picando en las fotos se amplian.
For months look for one of 8 unicable and nothing.
The unicable LNB of 8 years ago they stopped making, 2 and 4 without problems, jump to 24, 32 and 256, but 8 is not easy, some old remnant maybe.
By the way the 24 (40 €) I comment is cheaper than the 4 unicable + 2 legacy (normal LNB ) that costs 70 €.
Durante meses busque uno de 8 unicable y nada.
Los LNB unicable de 8 hace años que se dejaron de fabricar, de 2 y de 4 sin problemas, saltas a 24, 32 y 256, pero de 8 no es facil, algun resto viejo olvidado tal vez.
Por cierto el de 24 (40€) que comento es mas barato que el de 4 unicable + 2 legacy (LNB normal) que vale 70€.
PS: Sorry translations.
John Pykett
Persona non grata
Tururu
......You state that you are using Tuner B, on your VU+ Solo 4K, is this correct?
That is a problem, if there is no care (skip this):-doh
By default the antenna in A / Tuner1 is always better.
As we only have one satellite, we will not have problems.
To find channels we can select the tuner we want to use, but it will be easy to confuse us if we are not careful and can not find channels.
When watching / recording channels, you will first use Tuner1 / A.
The receiver will use the tuner as it is busy starting with the Tuner A / 1 provided.
With normal LNB, the change is instantaneous, with unicable, it will take a second if you change from tuner to a new one, indicating without signal, it is normal, the new tuner sends DiSEqC signals to communicate with the LNB, this responds by activating the new communications channel SCR / frequency, so take a few seconds.
The LNB only sends the SRC in use, all frequencies are off / SRC, they are activated at the request of the receiver.
Eso es un problema, si no tenemos cuidado (me salte esto).:-doh
Por defecto siempre la antena en A/Tuner1 es mejor.
Como solo tenemos un satelite, no tendremos problemas.
Para buscar canales podemos seleccionar el tuner que queremos usar, pero sera facil confundirnos si no tenemos cuidado y no encontrara canales.
Al ver/grabar canales utilizara primero el Tuner1/A.
El receptor usara los tuner segun esten ocupados empezando por el Tuner A/1 siempre.
Con LNB normales, el cambio es instantaneo, con unicable, tardara un segundo si cambia de tuner a uno nuevo, indicando sin señal, es normal, el nuevo tuner manda señales DiSEqC para comunicarse con el LNB, este responde activando el nuevo canal de comunicaciones SCR/frecuencia, por eso tarde unos segundos.
El LNB solo manda los SRC en uso, estando apagadas todas las frecuencias/SRC, se activan a peticion del receptor.
