Asiasat 8 (will be 4W)
Asiasat 8 is at 4 west the tracking is automated & will be corrected soon.
name of asiasat 8 rename to amos 7
Looks like a beacon, at the bottom of the 12.25...12.75 GHz range (Asian-style).
As a side note, just noticed AsiaSat leased to Amos-Spacecom already in the past.
AsiaSat 2 spent over a year (2010) at 17.0°E as Amos-5i.
AsiaSat 2 → AMOS 5i
Amos 5i at 17.0°E - LyngSat
adonis1
Current transponder status with 100cm dish from 4 west Amos 2 transponder power down when coming off the arc Real time satellite tracking for: AMOS 2 Nothing here on the 2 new European transponders 11139 H & 11175 H.
It will be interesting to compare this with the scan I will do on March 1st.
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
Zik TV was blasting through on 11620H 3600 at 10db a few minutes minutes ago and than disappeared. Not had any signal on this frequency for ages. There was hardly anything left I could lock into on Amos with the faded signal. I wonder if this is the new satellite testing.
May be AndyX I used to get Zik,
I did notice over the weekend that a couple of transponder went over 75% Signal Quality then went back down to 46% ? this may have been Amos-7 testing.
adonis1
Spacecom started commercial operation on satellite Amos 7
parabola.cz
When Ive had a cup of coffee I'll split the transmission stuff off into the fringe reception section
Edit - the reception stuff has now been moved here
Amos 7 (was Asiasat 8) 4W
This thread closed as Amos7 is on air
