Above my posts Feedsat DXer has posted a full pids table of these channels.
For SkySports2 HD you can edit the OTT service that gets downloaded and add
- Video pid 7020, Audio Pid (HE-AAC) 7021. These are the values that are converted from HEX to dec.
- Then in Service ID change the 3003 to something else like 2000 so that the Serviceref changes,
- the service type to 1,
- the service name to anything you like ie SS2HD,
- Check K and P flags
- In extra parameters you can optionally add
- c:00xxxx where xxxx is the HEX value of the video pid (ie 1b6c) and c:01xxxx for audio (ie 1b6d)
- save and send back to the stb.
Note again that sound should work, video may not (not standard dvb codecs). In the Webif also VLC may not work, you can stream the channel via MPC-HC if you are on Windows.
