Eutelsat 5 West A Steerable beam
rodscha
the very famous Algerian TV ,used to be called "l'Unique" because they ony had one channel...
Today 4 or 5 are available
also on astra 1 and hotbird
half French,half Arabic
Adam792
Cheltenham
I believe this is the feed for digital terrestrial transmitters in Algeria.
DTT backhaul seems to be what 5°W is mainly used for other than Fransat!
Sent from my SM-T580 using Tapatalk
aceb
Prof Tuner 7301 /
Sussex
This must have a sharp drop off as it moves north because it's always been available on demand on the south coast even on an 85CM dish. We use it a lot during the summer months to ID Algerian BII FM signals propagating via Sporadic E.
MCelliotG
Thessaloniki, Greece
It's coming fairly well on my 1.30 although I'm on the edge of the footprint, but this frequency has lots of variation in strength, I've seen it from 8 to 12 db within 24 hours!
Some days I can pick up 11059 H 23700 on the 88cm dish another day no signal on the 100cm & not a cloud in the sky ?
This satellite is quite old now launched in July 2002 with a design life of 15 years due to be replaced in 2018 with a new satellite Eutelsat 5 West B we will probably not get this transmission on the new satellite as it has tight regional beams like Eutelsat 9B @ 9 east,
HotBird-10 currently idle @ 33.1° East as Eutelsat 33E Eutelsat 33E at 33.0°E - LyngSat may be moved here after July if Eutelsat 5 West A if this bird is low on fuel & power.
blademedia
Sky
Its not as strong as other transponders at my location on the 1.2 but can lock it in all weather
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
Seeing this transponder in Scotland with 6db at the moment but it goes down to 4 dB sometimes.
aceb
Prof Tuner 7301 /
Sussex
22W 12673H is another Algerian mux but it doesn't have the complete radio line up that is carried on 5W.
TDA w SES-4 @ 22 west
Europe
MiddleEast
Algérie 3 Thalitha TV w F 514 670 Ara 1
Canal Algérie w F 515 680 Ara 2
Canal 6 feed 512 640 3
ENTV w 513 641 Ara 4
BISS
Algérie 5 (TV Coran) w F 516 650 Ara 26
Algérie 4 (TV Tamazight) w F 517 660 Ber 27
-R- Chaine 1 w 651 Ara 6
-R- Chaine 2 w 661 Ber 7
-R- Chaine 3 w 671 Fre 8
-R- Radio Sahel w 681 Eng 9
-R- El Wahat 652 Ara 10
-R- Ahaggar w 662 Ara 11
-R- Saoura w 672 Ara 12
-R- Tlemcen w 682 Ara 13
-R- Adrar w 653 Ara 14
-R- Ghardaia w 663 Ara 15
-R- Illizi w 673 Ara 16
-R- International Radio w 683 Ara 17
-R- Souf w 654 Ara 18
-R- Tindouf w 664 Ara 19
-R- Batna w 674 Ara 20
-R- Radio Jijel w 684 Ara 21
-R- Souk Ahras w 655 Ara 22
-R- Essouhoub w 665 Ara 23
-R- Naama w 675 24
-R- Chaine 1 w 685 Ara 25
-R- Radio Blida 621 Ara 29
-R- Radio Tiaret w 631 Ara 30
-R- Radio Médéa 691 Ara 31
-R- Radio Mila 611 Ara 32
-R- Radio Saida w 622 Ara 33
-R- Radio Skikda w 632 Ara 34
-R- Radio Mascara w 692 Ara 35
-R- Radio Guelma 612 Ara 36
-R- Ain Témouchent w 623 Ara 37
-R- Radio Khenchela FM 633 Ara 38
-R- Radio Bejaia w 693 Ara 39
-R- Radio Bouira 613 Ara 40
-R- Radio Relizane w 624 Ara 41
-R- Radio Annaba w 634 Ara 42
-R- Radio Tizi Ouzou 694 Ara 43
-R- Radio Tissemsilt w 614 Ara 44
-R- Radio El Bayadh w 634 Ara 45
-R- Radio Tebessa w 635 Ara 46
-R- Radio Djelfa w 695 Ara 47
-R- Ain Defla 615 Ara 48
Adam792
Cheltenham
canal algerie.png Just noticed the 5°W steerable beam versions scanned in in TVHeadend a couple of weeks back around when this thread was created, without me having realised!
No lock today with very overcast weather, and I haven't had them before on my 80cm.
88cm reception:-
100cm reception:-
ocean04
Vaasa
Western Finland (63N 22E)
With 2.4m it's slightly above lock here
Adam792
Cheltenham
algerie.jpg Clear and cold night here tonight! Getting lock at 4.9dB on these at the moment on my 80cm.
blademedia
Sky
Not much better here with a 1.2 Adam, I cant fine tune though only have large steps with actuator, I need to install a new reed switch when I find time.
Adam792
Cheltenham
It's very strange how they're coming through at all here! I've had the transponder in my list for two years now; TVHeadend scans it twice a day and I've only seen any sign of lock (rather than "Scan Failed") in the last month or so, as if something has changed. Last night was the first time I've actually managed to see the channels. Maybe they've upped the power a little?
