Just Sharing This 2.2mtr Elite / Precision resurection.
You're right:)
Have you seen the script examples here Pololu - 6.c. Example Scripts ?
Scroll down to Using an analog input to control servos
That's what I was thinking of using to monitor the LNB voltage to set V/H or L/R with a switch to change between linear & circular. Are you thinking of using the pot + sub-routines to read pot and write to pulse?
I don't know just yet G, iv'e only just got back in from taking the dog a walk since posting my last re: the Pololu. I'll give it a read now
blademedia
Sky
John and baldemedia
I apologize for the late reply because of problem with internet.
Many thanks for advice i will take your advice when i paint my dish, i have just watched video for paint by electric paint sprayer other choice with fast and lovely finish however i will use sponge roller it is less cost and easy for use.
rgds
Choice a nice warm day for painting/should I say wait for a nice warm day :D, don't rush the second coat make sure the first coat is fully dry, give it a light rub down with wet and dry before second coat, you can rub any not so good bits out at this point,
What 2.3 dish do you have ?, some pictures would be nice of the revamp :)
satmania
Tiger receiver. FUJI lnb. skystar usb hd pc card
Beghazi Barqa Cyrenaica
Really i don't know maybe prime sat or famaval :) it was warped here some pictures before and after modified the big collar to correct the shape.
That's some reenforcement there!
blademedia
Sky
Looks like a nice dish, I was expecting my dish to be warped and have to do the same thing as you, luckily it was still in perfect shape,
Well done on the modification, is the dish a spun dish ?, thanks for posting the pictures, maybe a admin could move your post to its own thread, it would be nice to see more of this dish :)
satmania
Many thanks blademedia
maybe it is, i tryed to make it in the perfect shape and have managed, but it was stand on edge so not sure to get spun dish, need to put it on stand to be sure if the shape is ok.
blademedia
Sky
Yes you will See better when its on the stand, put some strings on it and pull it into shape if necessary, you will see little circular lines on the dish face if it was a spun dish,
Please start a new thread here
DISH SETUP: Single sat, Multi-Sat & Motorised
Don't want to block Johns thread up, @Lazarus would you be so kind to move relevant posts to satmania new thread please
