eutelsat 9b reception signal
Kypros_Pambou
TBS:6985,6925,5925usb
5 Pace&Arris IPTV Gateways
Greek Cyprus
I can lock now the 12111 v with 1.9dB only
Kypros_Pambou
Greek Cyprus
I made and a scan to see the level of Italian beam.... I have the max SNR until now. The previous was 12.7-9 but never 13dB
Kypros_Pambou
Greek Cyprus
Something is changing with 12111 V because the Italian Beam from here is OK
I still have my Crazyscan of May, when 12111 V was Italian beam only, giving 8.0 dB.
Now in the mix with Nordic beam, the reading is about -1 dB although the peak is higher...
Netherlands has perfect mutual cancellation when both beams are on!
The clean Nordic beam 12149 V gives almost 10 dB, more than enough for lock.
The clean Italian beam 12341 V gives about 4.5 dB, well below lock.
May scan at the left, present scan at the right.
Lexzie
TBS 5925 USB-tuner
The Netherlands
Nothing on all Nordic and Italy beams with 120cm dish.
According to hvdh I should at least receive Nordic Beam on 12149 V?
I have 14dB on 12054 H (Wide beam).
16dB on 12130 H (Germany Beam)
16.3dB on 12207 H (Germany Beam)
Hello Lexzie, I now realise 12149 V is 8PSK 5/6 and needs 9.35 dB so actually I have little margin!
And with NL at the edge of the Nordic footprint, signal will drop a lot from NE to SW.
7.8db on 12149V but no lock still...
Kypros_Pambou
Greek Cyprus
Right now with 3.4m
9E - 12149 Ver (XtraTV Package) @ Nordic-Baltic Beam with AMS 3.4m from Cy Satellite Center.jpg
I am still not able to get a lock on 12149V, had a max of just over 8dB but no dice. 12111V is barely 2dB - I am guessing perhaps because of Italian and Nordic beam mixing?
4wd
Getting the picture
5 W, 9-13-19-28 E
T90:
12149V & 12111V very nordic 17 dB
12341V Italy nothing
12169H Greece 14 dB
12130H GE 14 dB
11881V wide 14 dB
blademedia
Sky
9,45 db needed for lock, getting 5.2/3 db 1.2 dish.
Do you have the 1.8m up to try with BM?
blademedia
Sky
1.8 is still in the shipping container and wont be installed, will get a 1.8 Elite later in year.
MCelliotG
Thessaloniki, Greece
New Multistream test tp
12111V 31400 8PSK 2/3 ID 11
The NIT reports a DVB-T test mux for 514MHz 64QAM 2/3
ADT DVB-T network maybe Italy beam? Normally, I should have more signal, but maybe it has co-interference with the Nordic beam!
I hate this satellite. I get 7dB from Nordic beam on 12149V but no lock. I barely get 1dB from 12111V - no idea whether this is Nordic or Italian bleeding over. Italian beam 12341V - 4dB - no lock.
I should plan for a 2.4m Channel Master to deal with 9E and Amos at 4W.... and SES-5 at 5E.
WaferSat
Laminas OFC-1200P, 30w-46e
Southern Finland near Helsinki
I haven't paid much attention to this bird ever, but this is my scan result now, not 100% sure I have all TPs on the lis (I synced with KoS before scan)
s-band
Essex
12111 1.9dB
12148 5dB
12340 2dB
Occasional detection of 12283 27500 8PSK
All V, No locks, 1.5m PF
nelson_b
Contributor
12111 1.9dB
12148 5dB
12340 2dB
Hi - Pretty much the same here on 1.8 c.m. for those transponders ...
The 2.4 manages to lock - 12148 at 9.9db (0.5db margin)
