- Jan 1, 2000
- Age
- 59
- Website
- www.sat-elite.uk
- UK
$10 for a nylon cog ?
Was a bit windy today to even properly adjust the tracking. Went to the pub instead.
Underwhelming.
I just about get 57e but it was stronger on an 90cm Fibo! 55e is stronger too - watchable 90% of the time but in winds the tall evergreen still knocks the signal out occasionally.
You do swing a lot, John
I still have some spares if you need some.
But a printer costs hundreds of pounds and you have to learn how to use it and design the thing....u can print one using a 3d printer...
Better check mine out..>You do swing a lot, John < Have you been talking to Chris ??
It's a good weather day today up our neck of the woods so going to see about repairing it. It looks very much like the cog failure that you suffered, luckily iv'e got two as spares-i'll keep you informed and some pics of how the limit switch assembly design failed later.
Could always buy a hobby lathe and start making things out of metal that last.u can print one using a 3d printer...
The problem started with the poor top retention metal tab for the spiral limit switch drive on the Venture actuator, no bushing is used and the metal tab was able to flex upwards somehow and the spiral drive became detached making the limit switch function to not operate. The SuperJack version used a bushing and was a better solution.
looks like a bad injury was sustained opening that casing.
