- Oct 21, 2006
- See signature
- North Somerset
You can email Laminas directly in Poland. That's how I got my 1.8m. Hm sat de also deliver
Good Night all
In one of my previous inputs
"My new motor (TM-2600 M2)will only move between 30W and 45E"
Has anybody had this problem with this motor, my previous STAB was slow but it survived many years,
and I was able to cover 58W to 53E using the same receiver.
Any ideas or help would be appreciated.
I have Superjack DG2100+ motor still in a box so changing this for the Technomate 2600 and see what happens
Regards
The Rascals
Laminas 1.5m and Stab 120 motor
You don't want to be putting a 1.5 on a stab.
Unless your old dish is clearly damaged or out-of-shape, chances are that it still does the job quite well.Thanks to everybody above for your help and info.
What improvement would I see by just upgrading to a
Laminas 1.2m dish compared to my 10 year old Joe Blogs dish
Regards
The Rascals
What improvement would I see by just upgrading to a Laminas 1.2m dish compared to my 10 year old Joe Blogs dish
Regards
The Rascals
Thanks for all the info folks
If I went 36V route what would I need to drive the dish with an arc 60W to 57 E I am at 8W
and is this much more difficult to setup than my STAB 120 motor.
Regards
The Rascals
Thanks blademedia
I am ok with what you describe above, its the actuator bit is where I have no experience with.
To cover the arc I mentioned above what size and make of actuator is required,
and how is this mounted on the dish and mast, and what cables are required.
Regards
The Rascals
Regards
The Rascals
