Octagon Sf5008 first 2018
OCTAGON SF5008 4K UHD E2 ENIG4MATIC
CPU: 7252S
Tuner Slots: 2 x Plug and Play
PnP Tuner Types: FBC S2x, Twin DUAL DVB-S2X, Twin DUAL DVB-C/T2
HDMI in & out
2GB RAM + 8 GB Flash
Ooh! Lovely... I was waiting for a new receive to come out. 4008 just wasn't quite complete for me.
BTW, these FBC tuners - can normal LNBs still be used on them?
digi247
NW
see sig
Yes Normal 'LNB's' can still be used but you will not get the functionality that and FBC LNB can give ie: the extra tuners
TJExcalibur
Out of this world.
Southern England
I have the Gigablue Quad 4k with fbc tuners and a Global Ivacom TWF-031 C120 Lnb. As a test I did 8 recordings at the same time on 19.2 Eastwith one being 4K. No problems.
MCelliotG
Thessaloniki, Greece
This will be my new receiver!! I wonder though, will it ship with all that tuner combo? If it has 8+2+2 tuners and you can connect another 11 virtual (usb or satip) tuners you get a staggering 23 tuners total. Is E2 capable of handling all of these? We'll see...
I barely manage to decipher what goes on on 1 channel, let alone 23 at the same time...
I assume that this will also be multistream capable?
digi247
NW
see sig
was that with 'One' tuner if ot was then thats pretty good as my solo 4k can only manage 4 recordings and watch another on one single tuner as the FBC should give 8 per tuner with an compatible LNB
MCelliotG
The FBC tuner I don't think so, but I'm certain the DVBS2X tuners will be the newer Silabs ones which of course will handle multistream, it would be odd not to since 4008 does.
Tururu
Assembled with recycled parts
Recycled as the owner.
Error, if it gives the additional tuners with normal LNB, but you lose the advantages of unicable.
LNB unicable.- Total bandwidth independence and polarity of all tuner.
LNB normal.- With a single cable connected to the Tuner A, you can only tune the band and polarity of the Tuner A (Master) in the other tuner that would be configured by default / is configured automatically (mistakenly indicate no), something similar to this :
"Not Configured-This tuner is set automatically" and yes, if it is set.
Error, si da los sintonizadores adicionales con LNB normales, pero pierdes las ventajas del unicable.
LNB unicable.- Independencia total de banda y polaridad de todos los tuner.
LNB normal.- Con un solo cable conectado al Tuner A, solo puedes sintonizar la banda y polaridad del Tuner A (Master) en los demas tuner que estarian configurados por defecto/se configura automaticamente (por error indican no), algo similar a esto:
"No Configurado-Este sintonizador se configura automaticamente" y si, si esta configurado.
Enigma2 guarantee that 18 Tuner handles them very well, 16SAT+2TDT (3 Slot ==> 4+4SAT, 4+4SAT, 2TDT)
I hope this time all the tuner works, in the SF4008 you can put 4 Tuner (has 2 slot), but the receiver only handles 3, some fellows put another USB-TDT.
With this information, it may only have 2 slots, I hope to be in error.
FBC S2x, DUAL DVB-S2X, DUAL DVB-C/T2.
Enigma2 garantizo que 18 Tuner los maneja muy bien, 16SAT+2TDT (3 Slot ==> 4+4SAT, 4+4SAT, 2TDT)
Espero que esta vez funcionen todos los tuner, en el SF4008 puedes poner 4 Tuner (tiene 2 slot), pero el receptor solo maneja 3, algunos compañeros ponen otro USB-TDT.
Con esta informacion, puede que solo tenga 2 slot, espero estar en un error.
FBC S2x, Twin DUAL DVB-S2X, Doble DUAL DVB-C/T2.
PS: The blind search, surely nothing/La busqueda ciega, seguramente nada.:-ohcrap:cool:
s-band
Essex
I'm totally confused. The only "Full band" chip set I have found is the Broadcom:
Broadcom Delivers Multi-Channel DVB-S2X Satellite Set-Top Box Chip
That article above gives an IF of 250-2350MHz whereas other Broadcom info suggests just 950-2150:
Broadcom's Full-Band Capture: Digital Tuning That Enables Much More Bandwidth With Much Less Energy
Broadcom debuts family of satellite STB chips with 4K support
The above ties in with Sky Q. I had problems using 250-2350 on a TBS6983, so how do they get around the aliasing problems?
Using TBS6983/6903 Below 900MHz (STV6120)
None of the above are "Unicable" as far as I can tell, are they??? Maybe it's a semantics and jargon problem.
I can't see an "FBC" chip set from SiLabs or anyone else. When I get time , I'll look for the standards as there is a lack of info about frequency ranges etc.
TJExcalibur
Out of this world.
Southern England
That the LNB is a twin tuner. Even so I doubt I will ever record more than 2 channels at once.
Looks like it has the makings of a good enthusiasts receiver I hope it has a blind scan like my SX88 with Ultra HD will make a nice addition to my collection.
Tururu
According to the rule, it would be Enigma2, and it just needs to work well to order one.
In 4K (UHD) currently only the Dreambox900 4K (300/368€) has a blind search and it works, a friend wanted to try 4K channels and blindly search in Astra to 19'2ºE, finding the channels of 10714 H (when it had several demos).
Segun la norma, seria Enigma2, ya solo falta que funcione bien para pedir uno.
En 4K (UHD) actualmente solo la Dreambox900 4K (300/368€) tiene busqueda ciega y funciona, un amigo queria probar canales 4K y realizo una busqueda ciega en Astra a 19'2ºE, encontrando los canales de 10714 H (cuando tenia varias demos).
Does the Dreambox900 4K come with the Blind Scan already active like the SX88 does ?
I don't know about the Dreambox, but the Amiko A4K comes with blind scan, scans in 4K easily and can stream 4.2.2 to the PC.........P1010002.JPG
MCelliotG
It's all in the drivers folks, and how these are provided to each manufacturer plus their own priorities. Clearly blindscan especially when it's hardware supported is not something that impossible to implement. Yes, Dreambox 900 has blindscan but they keep everything closed source, so where is their contribution?
Every other manufacturer so far has not invested in giving a blindscan implementation its deserved priority. Especially new generation receivers with great support such as SF4008 opted for what the mass demanded and guess what? That was Kodi (FFS). I've said that many times, DXers are the last part of the stick for manufacturers, nobody cares about our needs really! :(
I believe that once the first one releases blindscan it will run on every E2 box of the same specs in no time, but how long will it take to happen?
BTW about the Amiko A4K receiver, does it run Enigma2? If it's a closed firmware there is no comparison with E2, two completely different things.
maxi_power
120cm motorised dishes
PT
In my opinion, nothing new ...
Same chip type in same line as other brands for E2, the SF4008 not have blindscan, also not support feeds mpeg4 4: 2: 2 and this box will be the same thing.
It was necessary to appear something with other hardware, like Sigma or others, i do not know if Hisilicon chipset can handle it...
Not Enigma2 but it runs Android. But the apps it can run to me are the same. Enigma 2 is far too much of a car crash, but that is just my opinion.
it look similar hdmi in and out new brodcom cpu and work multi streambox and t2mi
I don't know about the Dreambox, but the Amiko A4K comes with blind scan, scans in 4K easily and can stream 4.2.2 to the PC.........View attachment 110943
I have looked through several film clips on the Amiko A4K Combo but none show the Blind Scan Function ?
Can you please give me a screen shot of the Blind Scan menu,
Thank you.
