OCTAGON SX88 H.265 HEVC HD
stephan94
Bavaria
It would be so useful if these updates were available over the internet when you switch on... ie the receiver says updates are available.
The update by internet is not active.
the only current way is by USB.
When you see the problems have some owners of U2C Denys
who can make updates through the internet, I think it's best to stay with the update by USB.
These are problems that require to use RS232 /minijack 3.5 to be resolved.
It's really not complicated with a USB and this avoids the risks of Internet outages.
rsync
Dish 120cm
Receiver vantage 1100HD
Computer Assembled PC
Italy
Hi stephan
RS232 on SX88, can you confirm this pinout ?
RS232 //// 3,5 TRS Connector
2 ------------->1
3 ------------->2
5 ------------->3
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
One of the firmware updates recently added a very updated satellite list, including all C, Ku and Ka satellites.
This needed a factory reset to enable itView attachment 111034
I did see this and download the software, reset the box, reset to the default da TR abase and rebooted. Not sure why it did not work for me but the satellite remained as before!
Weird...Did you do a factory reset? Sounds like you did. Worked OK for me.
stephan94
Bavaria
Hi stephan
2 ------------->1
3 ------------->2
5 ------------->3
I cann't answer.
I don't know, sorry.
Ditto.
As previously discussed, the box was originally aimed at the German market, but has sold far more widely than that.
Ok, I can understand why the additional cost of a DD+ licence was not originally considered necessary as German Channels don't make use of it but, in reality, Octagon are cutting off their nose to spite their face as there must be more than just thee and me who'd happily buy if they had a change of heart.
@mw963
They have a Facebook page, so maybe raise the issue there?
Pierangelo
150 cm from 80 east to 40 west + C lnb
Italy
I am a supporter of DD+, but I am used to handle difficulties..... ;)
with DNLA server I can even accept to watch it on a TV/PC/smartphone.
What they need to implement with a very low cost, and more or less is the same:
1) double audio on Multistream
2) subtitles on Multistrem/t2-mi (font for cyrillic too)
3) ability to change channel on DNLA , I have to switch them on decoder;
4) when the decoder is in fast version (always on) channels should work, but in my decoder only recorded files work.
Pierangelo
with a sx88 too now!!!!!
I did close my original FB account more the reasons you describe, but since starting a new account I have managed to tame the beast and I find it rather useful.
stephan94
Bavaria
And still no sign of French Multistream sound. I rather think now it's not going to happen, which is a great pity given that I'd have bought two boxes like a shot.
I already answered this question:
the license is included in the chips, it is not possible to do with a update.
The SX88 has been developed for the Slavic and Germanic market, and there's this French package that emits with this standard.
There are normal for this has not been studied during the development of the SX88.
You may be asked 1000 times to have his French, he will not come.
stephan94
Bavaria
Only solution (4. 2. 2) transmission using the SX88; record and then read to the PC this recording.
Here's an example.
Oh well. I'll save my money then.
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
I purchased a serial or rs232 cable for the SX88. Are there any recovery loaders or anything else that can be used with the rs232 cable?
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Central Scotland
Good evening
from SW 1. 04. 22 many satellites have been added, including belintersat.
Just load the SW and do a werkreset
Today came a new update.
rather it concerns the mediaplayer side.
Download OCTAGON_SX88_SW_EU_V10426_181017.rar (20.31 MB) now. Fast and easy at workupload.com
Trying
Firmware Version V10426 - 18/10/2017
it has new satellite database
Update: loaded new software and reset to factory as well as to default channel database. Amended satellite database, not there, just the one I initially changed one satellite in.
Tommybalbo
antenna 100 cm motorizzata ckarke tech 4100 - octagon sx88 . 57 est - 30 w
Italia
Buongiorno a tutti gli amici del forum, mi presento, sono Tommybalbo, un nuovo iscritto, ho trovato le vostre discussioni interessanti e profonde. Ho acquistato questo Octagon sx88 che trovo ottimo anche tenuto conto del rapporto qualità prezzo. Purtroppo ho un proiblema con sx88 disecq 1.2 il mnotore non si muove oppure va su altre direzioni, leggendo il post di stephan, andyx e william 1 sembra che hanno risolto il problema. Vi sarei grato se potreste scrivere ulteriori informazioni su come settare i satelliti e la numerazione. Chiaramente con il Clarke tech 4100 non ho problemi con il motore. Grazie un saluto a tutti
Good morning to all friends of the forum, I'm present, I'm Tommybalbo, a new member, I've found your interesting and profound discussions. I bought this Octagon sx88 which I find great even considering the value for money. Unfortunately I have a proiblema with sx88 disecq 1.2 the cursor does not move or goes to other directions, reading the stephan post, andyx and william 1 seem to have solved the problem. I would be grateful if you could write more information on how to set satellites and numbering. Clearly with the Clarke tech 4100 I have no problems with the engine. Thanks a lot to everyone
Admin note please provide an English translation in any posts as per rules
Tommybalbo
Italia
the problem disecq 1.2 I think it was framed by el bandido Hi
campag5242
Dishes: TD110, TD88
Receivers: SF4008, SX88, Samsung TV
NW UK
The oscam-emu bundled in the image is quite old, r741. An updated build with r752 would be appreciated.
At the same time, it would be great if this gxapi's 0x81 private descriptor in the capmt was injected with actual values for onid, tsid, namespace instead of 00's.
Tommybalbo
Italia
I changed my list manually & used some of the C band satellites such as Azerspace 1 then I relocated the other satellites
Set up in DiSEqC 1.3 USALS
My SX88 Channel List
53E Express AM6
52.5E Al Yah 1
52E TürkmenÄlem
51.5E Belintersat 1 (previously AzerSpace C band)
50E Turksat 4B
46E AzerSpace 1
45E Intelsat 904
42E Turksat 3A
39E Hellas Sat 2
36E Eutelsat 36B
33E Eutelsat 33C
28.2E Astra-2
26E Badr-4
23.5E Astra 3
21.6E Eutelsat 21
19.2 E Astra-1
16 E Eutelsat 16
13 E Hotbird
10 E Eutelsat 10
9 E Eutelsat 9
7E Eutelsat 7
4.9E Astra 4A
3.1E Eutelsat 3
0.8 W Thor 5/6/7
1.0W Intelsat 10-02
3 W ABS 3A (previously 1 west C band
4 W Amos 3,7
5 W Eutelsat 5W A
7.3 W Eutelsat 7W A
8 W Eutelsat 8W A
11W Express AM44
12.5 W Eutelsat 12W A
14W Express AM8
15 W Telstar 12
18 W Intelsat 901
20 W NSS-7
22 W SES-4
24.5W Intelsat 905
27.5W Intelsat 907
30 W Hispasat
Other satellites at this end of the arc can be added as & when they become active.
If an editor does not materialise then I will have to use EW5A C band so that I can fit in Bulgariasat @ 1.9 east & shuffle the satellites around 3 east to 5 west.
Hi William 1, I have not been able to do your own procedure I have problems with disecq 1.2 please kindly send me a copy of your database (dump) firmware Thank you
It will not work with DiSEqC 1.2 as mentioned in this thread that is why I used DiSEqC 1.3 USALS,
So have another go at making your channel list.
Tommybalbo
Italia
Thanks for the answer, so confirm me that the octagon sx88 has picks with disecq 1.2? Hopefully, they fix it with the next firmware. Now I've deleted the entire sat list I'm trying to manually insert satellites and frequencies. Hello
Pierangelo
Italy
Dears,
DNLA is working well, but could you fix:
- ability to change channels from the list, I have to do it on decoder first!;
- subtitles and double audio on T2-mi and multistream?
Thanks.
Pierangelo
