Hellas-Sat 3 @ 39°Ε
satkingdom
Turkey
10 fixed offset antennas ranging from 107 cm to 170 cm with multifeed systems on them.
Next Machina3D Satellite Receiver
North-East of Turkey
11.502 H 1639 Iqraa TV started.
satkingdom
Turkey
2night
vantage hd 8000s
120 cm dish
windows 7
friesland (nl)
Tommorow some transponders of Bulsatcom will be moved on Hellas Sat 3 on new frequency;
12647/H -> 12463H 30000 2/3 DVB-S2
12606/H -> 12424H 30000 7/8 DVB-S
12688/H -> 12482V 30000 7/8 DVB-S
12565/H -> 12444V 30000 7/8 DVB-S
On this time new freq.are not active
hoi,
postponed to 27 oktober
от 27ми. Октомври 2017г, предстои промяна в разпространението на Fen TV, Fen Folkore,Balkanika, Kanal3, Folklore TV и разпространението на радията от BSS групата !
11537 H 4000 has something new, with 7.5 dB, below lock for me...
12425 H 30000 7/8 QPSK DVB-S: still empty
12464 H 30000 2/3 8PSK DVB-S2: encrypted Bulsatcom package
Both about 18 dB.
88cm dish + TM5302HD
12425 H 30000 7/8 QPSK DVB-S is now a duplicate of 12606 H 30000
12464 H 3000 2/3 8PSK DVB-S2 is a duplicate of 12647 H 30000
Active transponders received here from 39 east with a 88cm dish
Orbitalzone_Delta
Multifeed & motorised
Istanbul
Both about 18 dB.
11537H 4000
A feed tagged as
"ADM Voyager 1”
for "World Judo Tour, Abu Dhabi Grand Slam, Oct.26 - 28,"
New Frequency Plan now started by the end of the month may see it's full implementation.
Kuwaiti HD feed now, 11458 H 7000 3/4 8PSK DVB-S2 "KTV Feed-47". Over 9 dB here.
There is more going on, too weak to lock now, between 11470 and 11490, probably these are regulars and feeds as listed on Flysat still under Hellas Sat 2.
MCelliotG
Thessaloniki, Greece
11474H, 11477H, 11484H all three moved to HS3 today, the signal is significantly lower for this beam's power as they use part of a single transponder.
In my area the signal on these transponders is stronger than it was before on HS2,while 11495 H and 11504 H I think it comes from a distant spot,M.E.(?)
Europesat
strong
Yemen
All new tps on H3 successfully locked
Any1 knows when will move tp of 11135 to H3?
High appreciated
2night
vantage hd 8000s
120 cm dish
windows 7
friesland (nl)
hoi,
some transponder changes:
12444 v 30000 now on 12214 v 7/8 30000
12424 h 30000 now on 12195 h 7/8 30000
I did a Blind scan of Multi-stream transponders no sign of NURTS Bulgaria Multi Stream on a new transponder maybe some will just move over to HS-3 on the same frequency ?
FlySat Hellas Sat 2/3 @ 39° East
satkingdom
Turkey
12.232 H 28333 is active but there are no channels active for the time being.
Kypros_Pambou
TBS:6985,6925,5925usb
5 Pace&Arris IPTV Gateways
Greek Cyprus
Confirm and now that there are no active channels ATM.39E - 12233 Hor ( RF Scan ) with 2.1m.jpg
Ka carrier only signals appearing again after a couple of months of no activity.
... these look very much like data when you observe for a few seconds in real time, the Promax is looking at the whole band in case something else comes on higher up the band.
satkingdom
Turkey
12.366 V 28.333 test frequency on.
