I was thinking of making a signal check on the satellites(from 42.0E-4/5W) I get with my toroidal(T90),installed almost 10 years ago
( #70).For objective reasons I can not change anything at the antenna,because it is installed on a wall on the 3rd floor of a block where I have access only with a platform,which,in parenthesis be said,I have to say is very expensive for my budget.For the same reason I can't change the lnb for 13.0E-Hotbird because not working a polarity
When I installed it I used the Lnbs,most Strong and Alps.Of course I would change all the lnbs used then with InvertoBU outside the Alps to the positions where we have two degrees of distance between the satellites.And I'm convinced that I'd get better signal at some positions.But under such conditions and for almost 10 years,my toroidal still works well and I can have a useful signal on all the satellites(15) on the lnb bar besides Nilesat.
For those interested to compare the signal with TOROIDAL T90 they have,considering the area where it is installed,here is my report with the signal of each satellite that I'm picking up with my toroidal.I hope to be useful for those trying to install a toroidal.
BTW,I have a desire addressed to those who have toroidal and dvbs cards,namely,to post the results they get with the their T90 antenna.
I guess I don't have to say that my report is aimed at those interested in the signal and not tv programs.
Thanks.
