Confused.
Annemarie Fleming
Manhattan freesat bow, hooked up to an existing satellite dish (probably Sky, but not sure.) I don't have my computer connected to the system.
Hastings, England
My Manhattan freesat box seems to work fine with the satellite dish in normal mode. BUT....when I attempted to delete a radio channel it froze, then when I turned the box off and on again (hoping to clear it) the signal has disappeared completely. I tried to go to freesat set-up menu, but all I get is the No Signal message on ALL channels. I have checked all the wiring connections, and all looks fine, but the signal check is still coming up as having failed.
Mickha
North West
Can you try another receiver, it is possible that your LNB has failed?
If the LNB is working correctly try doing a factory reset, on your receiver.
John Pykett
Persona non grata
Dish setup: 80cm Motorized Dish, TM-5402 HD M3. This setup goes from 1w to 28.2e
My computer setup: AMD Athlon II X4 645 3.10 GHz processor and 8GB of ram. Graphics Card is NVIDIA GTX 750 Ti. OS: Windows 10 64 Bit
Hucknall, United Kingdom
well check the capacitors on it because i had a problem with my old freesat box where there was a delay when powering on and the epg was slow to load all the data
Certainly bears a similarity to typical power supply problems, LNBs rarely fail and certainly if they do, it's not normally quickly.
I thought the Manhattan box was rather new. Has it been kept in a cupboard under the tv ?
Cheap electrical things don't like confined spaces.
Not just cheap devices. No electrical device with capacitors enjoys being cooked in an enclosed environment.
