AlComSat - will be 24.8W
new satellite plan to launch 11 December
will be 24.8w
VodzigorLans
Setup is down atm
RU, Saint Petersburg
So this is Algerian satellite... Any information about numbers of tp and maps since the launch is very soon? I have found nothing...
It will carry both transponders in Ku-band, Ka-band for civil applications and X-band, UHF and EHF for the needs of the military and strategic state sectors.
P.S. new 5W and 18W are going to have dedicated Algearia beams and they obviously have some capacity at 22W... is not that too much?...
Alcomsat 1 was launched a few hours ago and is now in transfer orbit.
Alcomsat 1 carries 33 transponders: 19 in Ku-band, 12 in Ka-band and two in L-band.
https://www.rapidtvnews.com/2017121150039/china-launches-algeria-s-first-communications-satellite.html
I do like a bit of Ka Band - especially way out West :D
I have had a web search for the down link footprint maps but no luck so far :(
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
Intercepted telemetric signals during the LEOP. :)
3625 H and 3954,5 V.
Alcomsat-1 arrived at 24.8°W.
Fathi Mekerbeche
AlcomSat-1
Algeria
is there any Frequency appears on AlcomSat-1. 24,8 W ?
How we can follow it now ?
Fathi Mekerbeche
AlcomSat-1
Algeria
11th Res. 609 Consultation Meeting
XX, 13-15 October 2014
Source: Algeria
Date: 10 June 2014
ALCOMSAT-24.8W
List of RNSS system characteristics to be provided to the Consultation Meeting per Item 11 c) of the Terms of Reference
I RNSS systems characteristics
I-1 RNSS ITU publication reference
RNSS network name
BR network ID
IFIC
ALCOMSAT-24.8W
112541248
API/A/8114
2739
ALCOMSAT-24.8W
113520121
CR/C/3389
2753
I-2 Non-GSO satellite system constellation parameters
Not applicable.
I-3 GSO satellites
I-3A GSO satellite system longitude
LonGSOi : longitude of each of the GSO satellites (degrees).
Network name
Longitude
ALCOMSAT-24.8W
24.8 W
I-3B GSO satellite system brought into use status
Frequency assignments in the 1164-1215 MHz band for the ALCOMSAT-24.8W satellite network are planned to be brought into use within 18 months after the start of the tentatively-scheduled Consultation Meeting.
I-4 Maximum circular orbit non-GSO space station (with non-steerable beams) pfd versus the elevation angle at 40,000 feet above the Earth’s surface (worst 1 MHz)
Not applicable.
I-5 GSO space station maximum pfd versus latitude and longitude at 40,000 feet above the Earth’s surface (worst 1 MHz)
Values for 1º lat/long spacing are included in the spreadsheet below.
I-6 Maximum off-axis EIRP density for non-GSO space stations with steerable beams, and antenna pointing information (worst 1MHz)
Not applicable.
I-7 Frequency/Satellite Matrix
Not applicable.
I-8 GSO/non-GSO satellite system spectrum
The level of spectrum emission in each 1 MHz relative to the spectrum value at the worst 1 MHz of the whole band (1 164-1 215 MHz) is provided below as the Spectral Adjustment Factor (SAF) in dB.
Normalised Signal Power Spectrum
Center Frequency (MHz)
SAF (d:cool:
SAF (d:cool:
SAF (d:cool:
SAF (d:cool:
1164
-5,13
1177
-0,05
1190
-9,57
1203
-36,79
1165
-2,92
1178
-0,10
1191
-11,78
1204
-37,14
1166
-0,70
1179
-0,15
1192
-14,00
1205
-37,50
1167
-0,60
1180
-0,20
1193
-17,50
1206
-37,86
1168
-0,50
1181
-0,25
1194
-21,00
1207
-38,21
1169
-0,40
1182
-0,30
1195
-24,50
1208
-38,57
1170
-0,30
1183
-0,40
1196
-28,00
1209
-38,93
1171
-0,25
1184
-0,50
1197
-31,50
1210
-39,29
1172
-0,20
1185
-0,60
1198
-35,00
1211
-39,64
1173
-0,15
1186
-0,70
1199
-35,36
1212
-40,00
1174
-0,10
1187
-2,92
1200
-35,71
1213
-40,36
1175
-0,05
1188
-5,13
1201
-36,07
1214
-40,71
1176
0,00
1189
-7,35
1202
-36,43
1215
-41,07
I-9 Results of the epfd calculation for an individual system in the worst 1 MHz of the 1 164-1 215 Mhz
________________________________
You have posted above details about the radionavigation payload in L-band.
Alcomsat-1 has payload in UHF, X, Ku and Ka band as well.
Being co-located with Intelsat 905 at 24.5°W, hopefully Alcomsat-1 will NOT use 10.95...11.2 and 11.45...11.7 GHz.
Several weeks of in-orbit testing should have started, maybe some members will find test carriers and report here!
s-band
Essex
There's a carrier at 12501.992MHz V at 22dB SNR in 1kHz at about that location (1.5m PF). I can't see any other beacons listed near that location and frequency in vertical polarisation.
There is a hint of it on CS but it doesn't show in the frequency scan.
Looks like it s-band.
With Gibby 1.2M
Lost 12501.95H, now 12301.95H.
There was a 12601V beacon earlier, gone now. Perhaps some testing imminent?
12318 H-test carrier
I am getting a signal on the TM5502HD satellite finder with 100cm Gibby.
