Trust
- Jul 18, 2004
- Age
- 77
- 1.8 m CM at SMR 1224 + Elev. with 7 lnb changer Ku (lin - circ) - Ka (lin - circ) C (lin - circ)
- Nijmegen Netherlands
Ok will do and thanks
To see howmuch the elevation must rise , tried that once with 2 Ku lnb's with 10 cm centerline difference at my 1.2 CMRight, I think this could be the problem, with the C band LNB sitting above your Ku LNB you will need to lift up the dish to bring the C Band into focus, so go to 19E ku then nudge the dish a little to the east, then lift the dish upwards with you elevation jack which will then bring the C Band LNB into focus. i had the same arrangement on my Channel Master 1.8 before I had the changer.
Have to adjust the dish elevation ± 7º higher
