TBS5520SE USB What's the catch?
Pierangelo
150 cm from 80 east to 40 west + C lnb
Italy
margusten
Lat 59.40 Lon 24.68
DR.HD F15, TBS-5925, Dream 800PVR, GM TripleX
Aerial AS24 polarmount 95E - 13E Ku+C, fixed 3M 28.2E, 27.5W ...
Estonia
Is anybody using TBS5520SE for Cable TV reception?
I downloaded latest Streamreader and CrazyScan2 but still no LU.
DVB-T and T2 was working fine.
But in DVB-C mode can not make LU to any transponder.
At same time DVBDream working fine?
My cable TV has these settings: 6875 Ks , I have to insert manually but it not helps.c2.pngc3.pngDVBdream.jpgc2.pngc3.pngDVBdream.jpg
CrazyCat
crazycat69.narod.ru
13E 4.8E 4W: Dish Variant CA-902 0.95m + 3xLNB Ku-Universal DreamSat DS8 + DiseqC 1.0
30W-95E: Dish Strong 0.95m + LNB Ku-Universal ALPS BSTE8-751B + Motor PowerTech DG240
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
MCelliotG
Thessaloniki, Greece
Can someone monitor in what increments the dB signal is measured with this card? It's for certain comparisons!
Does it go of 0.1 steps, more or less?
CrazyCat
crazycat69.narod.ru
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
0.25dB for all Silabs demods.
MCelliotG
Thank you CC, that's exactly what I suspected.
This means that the driver used in HD51's Si2166D tuner is..... but we knew that. The question is what do we do now?
CrazyCat
crazycat69.narod.ru
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
We can accept it :)
MCelliotG
The one currently used? Never!!!
The one used in DM920? Absolutely!!!
Pierangelo
Italy
Dears,
yesterday I received my new TBS 5520 SE.
The card seems ok, BUT I HAVE GREAT PROBLEMS TO MAKE IT WORK PROPERLY.
I have problems to make it recognize by softwares (Smartdvd, DVB viewer and progdvb) and after many attemps when I make it, it is enough to change satellite and sometimes even frequency to restart it again and struggle with software to make it recognize.
Then I did it only once to make work Diseq.
When the card decides to work, it is very good (tuner, t2-mi and multistrem).
I used even last drivers by the mighty Crazycat, but they are not working, a lot better with Florian's but I can't use diseq..... and I know it should work, once it did.... :(
This is not the way to enjoy it...
So I will pass next days trying to find help ......
any idea?
Best regards
Pierangelo
I use win 10, and the card seems recognise by the system with a usb pan as symbol in the tray.
I am using both usb plug (red and black)
Pierangelo
Italy
usb pan... is funny
:-lmao
Pierangelo
Italy
Might be this the reason: I use win 10 64x, Smartdvb is 32 bit?
Pierangelo
Italy
I will send it back on Monday....
Pierangelo
Italy
Only to close my posts. On monday it will be sent back.
From a technical point of view it is a very good card and I should have been happy with it, MIS, t2-mi, good reception, BUT in terms of reliability (maybe I am unlucky) very bad, you change between 2 programs and the card starts not working...
and then difficult diseq... and after 10 minutes.... too hot...
TBS could do a lot better... but the starting point is good, tuner is very good..
Regards
dxhound2003
Az Box Premium.
Triax 110 cm dish motorised.
Black Ultra LNB. Nov 2011 DrD F15.
Dundalk Ireland
The last computer I had was very bad with the TBS 5925. I found out that the graphics card was too weak. My current computer has a GTX 1070 card which might be overkill, but your problem could be the PC and not the receiver.
Pierangelo
Italy
I Agree but... It is my only PC and It Will be for many years to come....
Ciao
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Does anyone use a motor on this? I can't see a DC input so it's using USB power only.
Have been tempted to try one out.
I wouldn't dare. Some pci cards have additional power input for this purpose though....
I lie. I do use it to drive my motor but nothing more than sending DiSEqC commands to Vbox...
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Mulling over the 5922SE you have for sale!
margusten
Lat 59.40 Lon 24.68
Estonia
stpierre
Multisat Indoor Home Made 10 LNB 52°e > 5°w + Fibo 90cm USALS = 68°e > 45°w
Belgium
I have received a TBS 5520SE today.
This one don't work if I put only one plug USB!
With the 2 plugs, work very fine and fast,... I use it with USALS motor.
CrazyScan and EBSPro work without issue with MIS + PLS.
Blindscan work also with DVBDream3.4 + StreamReader1.2.15.
Some tests with DVBDream3.4 + StreamReader1.2.15.
I can receive DVBS2x transponders on 33°east.
Also the MIS (without PLS) on 12.5°west work fine.
But I can't receive MIS + PLS on e.g. transponders on 5°west with DVBDream!
Thanks and Regards
