(That would be a diseqc command.
USALS is just the software part in the receiver that calculates from site latitude and longitude and satellite longitude to the needed "Hour Angle", needed for the diseqc GotoX command, as I understand it all.)
I thought about that too, as a "solution".
The weird symptom isn't explained by that, though.
Is it because the limit switch elicits a motor stop command, a reset command, or something else? By the receiver, or by the motor itself?
And were the sent motor commands really identical?
You'd need a diseqc command reader, to test this, at the receiver/satellite-finder end.
Was no LNB attached to the motor, while testing? That could have had an effect, too.
Would it be possible to think of a testing setup (modifying the motor), where the symptom could switch to the other limitswitch? Which would make it clear that is really is a motor problem, not a receiver problem?
I wish the paypall complaint committee lots of wisdom.....
greetz,
A33
