lnb cover
parkiepie420
technomate tm-5402hd m3 /gibertini 1.25m sat dish 51e to 34w inverto black ultra single 0.2db lnb / titanium single output cband lnb
technomate tm-5402hd m3/triax 1.1m dish 53e to 24w inverto black ultra single 0.2 lnb
sheffield south yorkshire uk
ive just purchased this lnb cover from the famous auction website and I have to say its 100% helped with the signal level when it rains !!!
less than £20 delivered to Sheffield uk
well worth the purchase !!!!20171231_134632.jpg20171231_134645.jpg20171231_134638.jpg
Looks very nice (should do for £20) - but I believe that many people have knocked up something generally similar from old plastic bottles and metal brackets/strips (as used for hanging car exhausts and the like).
Reminds me to do something like that for the TD110 - think I probably have all the bits already.
Terryl
Custom built PC
Good to keep the rain off the LNB's eye, but what about the several tons of water in the clouds 10,000 feet above it??
Really really dark clouds can cause satellite signal rain/snow fade, no cover is going to help with that.
The only thing that realy works is a bigger dish, we in the CATV field use very large dishes to help with rain/snow fade.
@Terryl
Agree on both counts - "received wisdom" also says that it can help to protect the cover on the front of the LNB from UV degradation IF the shield is opaque rather than clear (seems that a "butchered" fruit juice plastic bottle might be a decent starting point - will have to "persuade" SWMBO to donate one! )
Jimmy H
Leek, Staffs
LG43UH661V with region 2 sky dish
Leek, Staffs
Keep the spiders nice and dry!
Terryl
Custom built PC
The problems with LNB eyes here is not due to UV degradation but to woodpeckers.
The little suckers like to try and put acorns anywhere they can, the funny thing was that there were no acorns in the LNB.
Now this LNB was from Invacom, they said it should have been bird proof, and they supplied a new LNB (for free) to back that up, the new LNB had a thicker cover.
The red color of the protective cover on this one was due to UV radiation, but it didn't affect the signal one bit.
@Terryl
Many years ago, I had several covers that actually split due to plastics degradation, but I haven't seen/much any evidence of that more recently. In early 2016 I took down some Lidl (=Comag!) LNBs that had been on a dish since around 2002, and they were OK and still working - OTOH, we don't get that much Sun, even in this part of the UK!
@Terryl
You should apply to return to Yorkshire - It's often sunny here.
Especially in the daytime.
hexah
Hadrians Wall
Timo demonstrated the old plastic bottle lash up was essential to get good results with the thin 23mm feed 'rocket' LNBs.
Home made Inverto MultiConnect cover
Yorkshire - that's "North of Watford" IIRC - so probably NOT!
parkiepie420
thankyou for all the replies it is helping a little on the hard to get satellites ie 7w etc !!!
Terryl
Custom built PC
If the satellite is hard to get then a cover will not make it any better, a bigger dish is the best way, or better coax could also help.
mikeisyou
Feed Hunter
England
91wMbtonfFL._SL1500_.jpgHow well does a feedhorn keep an lnb dry?
