OCTAGON SX88 H.265 HEVC HD
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Likewise I have suggested some modifications the the SX88 Blind Scan there & received some polite replies :)
Good customer service goes a LONG way, I will always recommend somewhere if they give good service. And I will buy again.
In fact I will buy the SX88+ over the Edision because Octagon have been very helpful.
^^^^^^^ Just waiting for WoS to get stock ......
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
Good customer service does go a long way. So does bad customer service.
Octagon also asked me in 2017 to prepare and send .ts files so problems could be solved which I did. I checked several months later and these files had not been downloaded. So I did all of that work for nothing.
Maybe others will have better luck, but I am not interested in buying anything else from Octagon unless they can actually fix the things they say they will fix. Saying you will do something and never doing it does not cut it!
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
mikeisyou
Feed Hunter
England
Anybody else finding that the remote control doesn't respond when you switch from a pal channel to a ntsc channel?
Fix: to unplug receiver and plug back in
Not even the power off button works
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Some great valid comments here re: Octagon customer service and attitude........nice to see and as I think 'william-1' referred to....one of the best receivers he has reviewed in the last 25 years.
At the mo enjoying on the Octagon live golf from Florida. :Y
stephan94
Bavaria
Good Morning mikeisyou
I just did the test on the same satellite as you.
It works perfectly.
I tried using the channel editor or going directly from one channel to the other.
I do not have any problems .
A question to try to understand your problem: have you worked with Satdreamedit?
here the little video where everything works.
Download NTSC PAL1.zip (3.94 MB) now. Fast and easy at workupload.com
mikeisyou
Feed Hunter
England
It works perfectly.
Thanks for testing, maybe its an issue only related to the SX88+ and not the SX88.
Peugeot 207
Dish 120cm
Dish 90cm
Octagon SX88
VU ZERO 4K
CROATIA
Sorry guys if was already asked.
How to make screenshot with osd from this box?
Regards
stephan94
Bavaria
No it is not ,my test is with a SX88Plus
but have you worked with satdreamedit ?
satdreamedit causes a lot of problems as soon as you work on satellite lists or programs.
A lot of unexpected problems have come from that.
If that's the case I advise you to go back to a setting that has not been changed.
good luck
stephan94
Bavaria
Regards
Hi peugeot 207
I'm doing the screenshoot with my Canon PowerShot SX220HS
mikeisyou
Feed Hunter
England
good luck
I haven't heard of or used satdreamedit. All the plugins and add-ons installed are default.
stephan94
Bavaria
I think we should change the file because we are here in the SX88.
There is already a folder SX88PLus
mikeisyou
Feed Hunter
England
The SX88 and the SX88+ in theory are the same box with the exception of the DD+ chip. So it should be affecting both boxes. The problem is being caused by my Video/Output settings hopefully this can be sorted soon by Octagon.
While the Octagon SX88 is a very good receiver however it would be a better guide to signal quality if it was in dB % like the Dr HD & TM5400 M3,
The SX88 gives me lots of SQ=100% that display the correct SQ more accurately on the TM6902HD,
Just Sharing This - Strongest transponders
mikeisyou
Feed Hunter
England
Yep the signal quality on the SX88 is pretty rubbish, on the transponders that it can't lock it gives a reading of 0% even though there is some signal there. I was watching a channel on Badr 26e in poor weather and the signal reading was flicking between 56% and 0%.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Is that the SX88+ you have or have you had a SX88 as well?
mikeisyou
Feed Hunter
England
I have the SX88+ and not the standard SX88, they both run on the same firmware so I'm presuming the issues on one will be the same on the other (apart from the DD+ sound problem).
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Would you say it's just a poor signal meter reading on it or is the tuner actually quite weak too?
When you were dropping signal on Badr 26 did you try another box?
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
No complaint about the sensitivity of the standard SX88. The signal meter is a bit of a dull instrument which means fine tuning the dish to get the best signal can be a lengthy guessing process.
