OCTAGON SX88 H.265 HEVC HD
mikeisyou
Feed Hunter
England
Would you say it's just a poor signal meter reading on it or is the tuner actually quite weak too?
When you were dropping signal on Badr 26 did you try another box?
The tuner I would say is really sensitive, I'm now able to watch more channels on the weaker satellites like Badr and Nilesat but I don't know how much is down to the new coax cable I've laid down and I can't compare boxes properly because my Spiderbox 7000HD has gone a bit faulty.
I was doing a blindscan on 21.6e the other day on the SX88+ and it took a good 30/40 minutes to complete. The channels I did scan in were really weak in signal (because of the beam they're on) so I think this was partly the issue. The quickest blindscan I've seen it do is 19.2e in about 4 minutes.
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Sounds really good for the money!
You got that WF125 sorted in the end then?
mikeisyou
Feed Hunter
England
I had to cut the side of the cable for the connector to fit on, I'm still on the lookout for the right connectors but it'll do for now, thanks for your help.
I've added some more bugs/improvements to my spreadsheet list, feel free to have a look :cool:
mikeisyou
Feed Hunter
England
More bugs:
Flickering picture of some channels, the problem is more noticable when theres on-screen graphics -
(Bein Sports News HD on Nilesat)
Unable to Record any channel to memory stick of 16gb formatted in NTFS and also in FAT32, I've also tried both USB ports.
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
I am not upto date here, what's this about the SX88 + ?
The + model was released very recently, with a new chipset that supports DD+ Audio, in response to reviews and feedback from users of the original model.
We have a dedicated Topic for it in the same sub-Forum.
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Ok thanks just that addition then. Btw I see the SX88 for £64 new on eBay, bit cheaper !
stephan94
Bavaria
Octagon_sx88_v1.04.53_20180329_EU NEW SW - 29 03 2018
SW Update: Menu - Settings - SW Firmware Update: USB - OK Button
English:
- Upgrade Video Driver
- R9 Österreich HD Problem fixed (Astra 19,2°E)
- ONE HD Problem fixed (Astra 19,2°E)
- Stalker Login Time improved
- Nashe TV Improvements:
- Recall Function added
- Reminder last used channel
- Streaming choice function added
- EPG function improved
- Nashe TV Login changed "oct_..."
- Russian Lang, string improved
- Nashe TV FAV & Groups improved
- Button Option function added
- FAV Button direct on Live TV usable
- Green Button for VOD - Live TV added
Download OCTAGON_SX88_SW_EU_V10453_290318.zip (35.04 MB) now. Fast and easy at workupload.com
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Regarding the the multi stream capabilities how is the SX88 better then the openbox SX6 i.e does it have this :-
"Hi unfortunately PLS ROOT CODE and T2-mi support will not be implemented (company confirm)
stephan94
Bavaria
I will wait for the modification of the Quality Signal in dB that has received a favorable response from Octagon on facebook :)
As it looks like a total channel list rebuild with upgrades after the latest upgrade advised by stephan94 post in #710 of this thread o_O
Upgraded my box without losing any settings as regards to channels, and user settings. Perhaps Stephen just meant the Stalker TV back up???
stephan94
Bavaria
Hello
I just redo the Update, but with another USB, this time it worked.
As said scopus, it works but be careful.
This is the first time I have this kind of problem.
stephan94
Bavaria
New SW 1.04.55
Octagon_sx88_v1.04.55_20180404_EU NEW SW - 04 04 2018
- Upgrade and improved Stalker
- Stalker engine update
- Stalker Login speed improved
Pay attention to the USB used.
Always take an empty USB otherwise it can cause the loss of the setting
sami noor
ASTRA 19°E/5°W/7°W
ALGERIA
AC3+ IS OK WITH ALL RECEIVERS OCTAGON SX8/SX88/SX88+
So all channels use AC3+ sound are OK
here a video on 5°W french MIS/PLS with dolby digital plus sound and all OK
sami noor
ASTRA 19°E/5°W/7°W
ALGERIA
Octagon_sx88_v1.04.56_20180409_EU NEW SW - 09 04 2018
SW Update: Menü- Einstellungen - Software Update: USB - OK Taste
English:
- Box Mode added:
- Default: S2 + IP
- System Information: Pin 9090 --> IPTV OTT Modus
- Back to S2 + IP --> System Information: PIN 9090
- Video driver updated
- Nashe TV A/V match
- USB Config function added for Stalker:
- File STALKER.txt: add your URL on pc
- Stalker Menu: Blue Button for USB import
- Hotkeys F1, F2, F3 und F4 (red, green, yellow and blue) change to global
- Hotkeys using in all Full Screen Menus
- Hotkeys add for Nashe TV
- Main Menu ICON swtich to classic Main Menu with OPTION Button
- Stalker CH List each Page change to 12 Channels
German:
- Geräte Modus eingefügt wie:
- Werksseitig: S2 + IP
- Zurück auf S2 + IP --> System Information: PIN 9090
- Video Treiber aktualisiert
- Nashe TV A/V Anpassung
- USB Config für Stalker eingebaut:
- Datei STALKER.txt URL eintragen
- Stalker Menü: Blaue Taste USB Import
- Hotkeys F1, F2, F3 und F4 (rot, grün, gelb und blau) Funktion auf Global geändert
- Schnellzugriff in allen Voll Bildschirm`s
- Hotkey Tasten für Nashe TV eingebaut
- Hauptmenü ICON wechsel auf Klassisch Menü mit OPTION Taste
- Stalker Programmliste pro Seite auf 12 Sender geändert
Turkish:
- Cihaz Moduu eklendi:
- Fabrika cikisi: S2 uydu + IP OTT
- Sistem bilgileri: Sifre 9090 --> IPTV OTT Modus
- S2 Uydu + IP Modusa geri: Sistem bilgileri: Sifre 9090 --> IPTV OTT Modus
- Vidyo sürümü güncellendi
- Nashe TV A/V düzeltmeler yapildi
- Stalker USB den yükleme özelligi eklendi:
- Dosya STALKER.txt URL nizi pc de girin
- Stalker Menü: Mavi Tus USB import
- F1, F2, F3 ve F4 (kirmizi, yesil, sari ve mavi) hizli erisim tuslari global eklendi
- Hizli erisim tuslarini her tam ekran menülerde kullanabilirsiniz
- ICON Men den klasik Menüye gecis tusu OPTION tusu olarak degistirildi
- Stalker Kanal listesi sayfa basi 12 Kanal olarak degistirildi
Menü - Einstellungen: PIN 6363 --> CAS Setting (unten - bottom)
Menu - Settings: PIN 6363 --> CAS Setting (Bottom)
FTP aktivieren: Menü - Einstellungen - Sonstige Einstellungen: FTP Server EIN (ON)
FTP enable: Menu - Settings - Misc settings : FTP Server ON
FTP login: root , PW: sky1122
Webif (Web Interface) browser: IP 192.168...
Fast key Editor: TV Mode - Press 0000 Pin. (Biss, Power Vu)
Telnet (Puty): Login: root, Password: sky1122
***** config import USB: use *****.iks file
Stalker URL Password: 6969
WebTV Password: RED Button (Rote Taste) - +18 - Exit and WebTV again
Kindersicherung PIN 0000, Master Passwort 0088
IPTV OTT Modus: System Information - PIN 9090
S2 + IP Modus: System Information - PIN 9090
09/04/2018
OCTAGON_SX88_SW_EU_V10456_090418.rar
Laser
Updated the box direct from the internet. Easy. Seems the best way to do it. Great box. Thanks Octagon!
Pierangelo
150 cm from 80 east to 40 west + C lnb
Italy
Sorry, but DD+ works now?
