AlComSat 24.8°W
the tda Algeria will be stop on 22w ?
No I do not think so as 22 west serves a much larger region including Europe,Middle East,North & West Africa,
Whereas 24.8 west is a regional service that just serves Algeria & North East Africa.
Much the same as the Eutelsat 7 West A @ 7.3° West footprint for TDA from this location serves the whole of North Africa & The Middle East.
You are right in principle,but basically I'm asking if Algerian operator wants to keep the same package on two nearby satellites?If the package TDA at 22W is addressed to the Algerians in Europe and if the signal on the AlcomSat-1 has large variations day/night on our continent ,as it is now,then yes,we can believe that this package will remain at 22W.But,if there is no a technical problem to AlcomSat-1 and the satellite has no problem of inclination,as we can see this phenomenon in Europe,then the economic logic require the Algerian operator to drop the 22W beam.To which we can add also motivation national,a feeling which feeds the pride of many former colonial countries.
And there is one more thing that should be taken into account,the tendency of Arab countries and North Africa to cover their area of interest.This is clearly seen also from the map above.It's a very much MENA footprint that we find on many satellites Arabs or Eutelsat that has coverage on this area.
And if Algeria still wants to offer for their countrymen in Europe, they can do what the Arabs have done with the MBC package, two transponders covering two different regions from the same position,26.0E, one for their area-11284 V,27500,3/4, and one for East MENA-11270 V,27500,5/6,that has good coverage in Europe.In my area I have a signal of 12dB on this transponder.
But no matter what we think of the TDA package on SES-4 and if everything is ok with the signal in their area,then we can expect this package to stop transmitting from this position,perhaps even later this month.Wait and see.
Certainly,state TV channels will migrate to AlcomSat-1,they will be forced to do so, but it is not certain that private ones will do the same thing.The last will only do so to the extent that it is a financial advantage,but also if their editorial policy is free from the interference of the political/(religious) factor.
And let's not forget an important thing,often technology is developing faster than the mentalities of a people, especially in traditional societies.And as we know from recent history,the one who has modern technical means can communicate or,if you want,manipulate more easily through propaganda.I hope not to be in this case.
stephan94
Bavaria
I do not know if you still have the signal on this satellite,
since Germany, the signal has dropped dramatically.
nelson_b
Contributor
Hi stephan94
Not a hint of signal here at the moment on the 2 transponders that "were" active - using 1.8 cm and F15 receiver.
regards ...
The signals here have been progressively getting better over the past couple of days but today nothing ?
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Alicante with 1.2m............nada, nothing! :N
anto@
italy
nelson_b
Contributor
Back up again this morning ... with strong signals previously only seen in the evening here ....10.8 db on 12.204 and 11.6 db on 12.160 ... on 1.8 c.m.
Good signals on the 88cm dish here,
12160 H 30000 7.2dB
12240 H 30000 7.6dB
stephan94
Bavaria
Complete reverse of last few days signals on both transponders this morning but nothing this afternoon slight signal showing this evening on 12240 H 30000 via the spectrum analyser.
Only 12240 is active this morning 57% SQ with 100cm + TM5302HD,
88cm + TM M3 = 7.3dB.
stephan94
Bavaria
of Paris on the only active transponder 12240
with 1.20 m just 6.0 dB this afternoon.
Dave5118
1.5m Gibertini with Inverto 5434 Unicable Hybrid LNB.
TBS 6903 with EBSPro
Vu+ Uno 4K SE
Edision OS Nino Pro
Starsat 2000HD Hyper
Sky Q Silver
Sky minidish with Sky Q Hybrid LNB
Nr Manchester UK
Is it just me, but but it seems these channels are available all the time now, instead of periodically?
Both transponders working OK on 100cm dish only 12240 H 30000 working on 88cm dish good strong signals since the transmissions changed from DVB-S & 3/4 FEC to DVB-S2 2/3 FEC :)
Dave5118
Vu+ Uno 4K SE
Edision OS Nino Pro
Sky Q Silver
Nr Manchester UK
Signals seem the same here tbh, but now it seems to be available all the time now, whereas before it used to 'disappear' at certain times of the day.
