Listen Up Octagon SX88+
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
I tried installing the SX88 firmware on purpose when I first got it, fortunately it wouldn't let me :D. I've been told by Octagon they're planning on introducing the dB and BER so thats awesome news.
10722 V 27500 on 7E also doesn't work so there's definitely a problem with scanning radio channel only transponders.
Ok with me on both the SX88 and the SX8...Something is a amiss at your end..P1010014.JPGP1010015.JPG
stephan94
Bavaria
The first time I saw the signalbar of the SX8 HD One, I told octagon to put the same on the SX88(+)Signal bar.jpg.
On the other hand for the dB, I hope but I am not very optimistic.
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
also with a recording of a Multistream program (Arte 11509H 5 ° West) the subtitles are saved without any problem.View attachment 116083
I get no signal at all on 11.509 with my tbs 5925 or openbox sx6 which also decodes some multi streams. Is my LNB the reason or my location ?
stephan94
Bavaria
This is the point I've repeatedly made - users should really be subject to occasional updates for genuine improvements to software that has been thoroughly Beta-tested. Yes, Octagon listen and respond, but that shouldn't need to happen on the scale we' ve seen.
mikeisyou
Feed Hunter
England
Indeed, I admire Octagon for keeping up the struggle against bugs, but this piece-meal approach seems a bit slip-shod. Still, better than no R&D at all I suppose.....
They've said themselves they're very busy at the moment, the impression I get is they wanted to get the stalker improvements out the way so they can work on the big stuff. The next update should be next week :D
Martin88
Octagon SX88+ with
1m motorised dish
Gloucester, England
Attention with this SW you lose all his setting. Also if you made a backup, he does not take this backup.
I've just got around to applying this update. I didn't lose any settings :)
mikeisyou
Feed Hunter
England
Another day another update, the latest version is now v1.04.56. I spoke with Octagon and they've said they're still working on the dB/BER implementation.
sami noor
ASTRA 19°E/5°W/7°W
ALGERIA
Octagon_sx88plus_v1.04.56_20180409_EU NEW SW - 09 04 2018
SW Update: Menü- Einstellungen - Software Update: USB - OK Taste
SW Update: Menu - Settings - SW Firmware Update: USB - OK Button
English:
- Box Mode added:
- Default: S2 + IP
- System Information: Pin 9090 --> IPTV OTT Modus
- Back to S2 + IP --> System Information: PIN 9090
- Video driver updated
- Nashe TV A/V match
- USB Config -- # -- added for Stalker:
- File STALKER.txt: add your URL on pc
- Stalker Menu: Blue Button for USB import
- Hotkeys F1, F2, F3 und F4 (red, green, yellow and blue) change to global
- Hotkeys using in all Full Screen Menus
- Hotkeys add for Nashe TV
- Main Menu ICON swtich to classic Main Menu with OPTION Button
- Stalker CH List each Page change to 12 Channels
German:
- Geräte Modus eingefügt wie:
- Werksseitig: S2 + IP
- Zurück auf S2 + IP --> System Information: PIN 9090
- Video Treiber aktualisiert
- Nashe TV A/V Anpassung
- USB Config für Stalker eingebaut:
- Datei STALKER.txt URL eintragen
- Stalker Menü: Blaue Taste USB Import
- Hotkeys F1, F2, F3 und F4 (rot, grün, gelb und blau) Funktion auf Global geändert
- Schnellzugriff in allen Voll Bildschirm`s
- Hotkey Tasten für Nashe TV eingebaut
- Hauptmenü ICON wechsel auf Klassisch Menü mit OPTION Taste
- Stalker Programmliste pro Seite auf 12 Sender geändert
Turkish:
- Cihaz Moduu eklendi:
- Fabrika cikisi: S2 uydu + IP OTT
- Sistem bilgileri: Sifre 9090 --> IPTV OTT Modus
- S2 Uydu + IP Modusa geri: Sistem bilgileri: Sifre 9090 --> IPTV OTT Modus
- Vidyo sürümü güncellendi
- Nashe TV A/V düzeltmeler yapildi
- Stalker USB den yükleme özelligi eklendi:
- Dosya STALKER.txt URL nizi pc de girin
- Stalker Menü: Mavi Tus USB import
- F1, F2, F3 ve F4 (kirmizi, yesil, sari ve mavi) hizli erisim tuslari global eklendi
- Hizli erisim tuslarini her tam ekran menülerde kullanabilirsiniz
- ICON Men den klasik Menüye gecis tusu OPTION tusu olarak degistirildi
- Stalker Kanal listesi sayfa basi 12 Kanal olarak degistirildi
Menü - Einstellungen: PIN 6363 --> CAS Setting (unten - bottom)
Menu - Settings: PIN 6363 --> CAS Setting (Bottom)
FTP aktivieren: Menü - Einstellungen - Sonstige Einstellungen: FTP Server EIN (ON)
FTP enable: Menu - Settings - Misc settings : FTP Server ON
FTP login: root , PW: sky1122
Webif (Web Interface) browser: IP 192.168...
Fast key Editor: TV Mode - Press 0000 Pin. (Biss, Power Vu)
Telnet (Puty): Login: root, Password: sky1122
***** config import USB: use *****.iks file
Stalker URL Password: 6969
WebTV Password: RED Button (Rote Taste) - +18 - Exit and WebTV again
Kindersicherung PIN 0000, Master Passwort 0088
IPTV OTT Modus: System Information - PIN 9090
S2 + IP Modus: System Information - PIN 9090
09/04/2018
OCTAGON_SX88plus_SW_EU_V10456_090418.rar
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
So I've ordered a SX88 but should I have got a SX88+ ? Will I get all the audio from the various multistreams on 5w for example with just a SX88 ? Btw can anyone decode 12.711 on 5w ?
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
If any of those multistreams are Dolby Digital+ you need the SX88+
sami noor
ASTRA 19°E/5°W/7°W
ALGERIA
If you want 5°W all multistream with AC3+ sound (DD+) you must order SX88+ all works well also 12711 LA 7 HD and all italians MIS/PLS + all French MIS/pls.
mikeisyou
Feed Hunter
England
If you want audio from the french channels on 5w then yes you should have gone for the SX88+. The italian channels (5w) on the other hand will work fine. 12.711 on 5w will decode fine on the SX88 and SX88
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Ah ok damn, thanks for info but too late now to cancel :(
