zorbua
- Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
- Malta
It's on the Europe/African Beam.
and now I can finally get the frequency of the north of Bavaria with 1,20m
I knew that, but I'm making an important note for those in Europe who want to receive this transponder.
Over two/three hours is going to be better signal on 12722 H![]()
You might get another 2db with a 1.2, if that will be enough for you to register a lock.Hi -
I,m getting 126 channels from this sat -- using a " fixed" 90 cm Channel master with only 2.4 elevation view at my location ..... but cannot get a lock on 12722 H ..... signal is floating between 5.0 and 6.0 db ... nowhere near enough..
I wonder if a 1.2 dish would do it ? (i have my doubts) ... i,v watched this SABC news channel many years ago - it would be good to have it again.
Regards.
<< ...Over two/three hours is going to be better signal on 12722 H>>
To me, in the morning it is far better, in the late evening it starts blinking ... (signal up and down then no signal.... then up down then no signal)
Northern Italy
Well if I would go for a 1.2 I make sure that I will get a general all around reception (not just for one particular Sat)
otherwise it will be a no go.
Hi -
I have a motorised 1.2 c.m. channel master in use here .. but cannot see 68.5 E with it due to a building roof .. i may "borrow" the dish face and swap it with the 90 c.m. just out of interest .. My view of 68.5 E with the fixed dish is through a gap between buildings and cannot really a be permanent fixture ... i could have it there for a few weeks though.
A bit windy here today for removing the 1.2 dish face .. its in a rather exposed position ..![]()
This is 70.5e.MTA from 11211H/5110 --> HD on 12681V/16046
Yes very strong signal has penetrated from70EThis is 70.5e.
Good on you...Now you are in a better position to have a go with your 1.2Hi -
Managed to lock - scan - and get a frozen image with the 90 .c.m. ...... so i,m encouraged to try the 1.2 now
I have no signal on this transponder!
