Intelsat 20 68.5°E
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
At this Moment signal is 10.4db with I mtr Dish DR.HD F15 Receiver.
stephan94
Bavaria
and now I can finally get the frequency of the north of Bavaria with 1,20m
It's on the Europe/African Beam.
I knew that, but I'm making an important note for those in Europe who want to receive this transponder.
Over two/three hours is going to be better signal on 12722 H :)
nelson_b
Contributor
Hi -
I,m getting 126 channels from this sat -- using a " fixed" 90 cm Channel master with only 2.4 elevation view at my location ..... but cannot get a lock on 12722 H ..... signal is floating between 5.0 and 6.0 db ... nowhere near enough :( ..
I wonder if a 1.2 dish would do it ? (i have my doubts) ... i,v watched this SABC news channel many years ago - it would be good to have it again.
Regards.
popovp
My system:Receiver-Ferguson Ariva 102E HD, Sky Sat 9900FTA+emu;Ferguson FX-6600CR/OCTAGON SF318 soft;LNB-Sky Sat, universal, 0,2dB;1.17x1.06m offset dish ;Diseqc 1,2 +USALS Moteck2100A motor; 1,2m parabola+0,3dB Inverto @ H-H Strong SRT DM 2100
Varna, Bulgaria
Pierangelo
150 cm from 80 east to 40 west + C lnb
Italy
<< ...Over two/three hours is going to be better signal on 12722 H>>
To me, in the morning it is far better, in the late evening it starts blinking ... (signal up and down then no signal.... then up down then no signal)
Northern Italy
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
Hi -
Regards.
You might get another 2db with a 1.2, if that will be enough for you to register a lock.
Satalitics
6ft pf dish
Kenya
Northern Italy
:-clap
nelson_b
Contributor
Hi
Thanks for your reply .. I will monitor signal levels for a while to see if its worth a try .. although signal levels seem quite a bit higher at times this morning .. (up to 8.0 db) the fading effect due to my very low elevation here - is worse...( down to 3.5 db)
According to Lyngsat i need 9.4 db to lock ... so its unlikely that i will get any stability even if i manage a lock :( ...
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
Well if I would go for a 1.2 I make sure that I will get a general all around reception (not just for one particular Sat)
otherwise it will be a no go.
nelson_b
Contributor
Hi -
I have a motorised 1.2 c.m. channel master in use here .. but cannot see 68.5 E with it due to a building roof .. i may "borrow" the dish face and swap it with the 90 c.m. just out of interest .. My view of 68.5 E with the fixed dish is through a gap between buildings and cannot really a be permanent fixture ... i could have it there for a few weeks though.
A bit windy here today for removing the 1.2 dish face .. its in a rather exposed position .. :)
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
Hi -
If you feel like having a go without incurring too much trouble.....otherwise just let it pass......
popovp
Varna, Bulgaria
nelson_b
Contributor
Hi -
Managed to lock - scan - and get a frozen image with the 90 .c.m. ...... so i,m encouraged to try the 1.2 now :)
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
MBrincat
1.2m motorized dish, VBOXII positioner, Titanium LNB 0.2dbs,
Dreambox 800HD
Malta
I have no signal on this transponder!
Pierangelo
Italy
Last week has been reactivated 12722 H,26656,1/2 with a religious package-provider DamSky Satellite
stonesatellite
Vu+ Duo 4K SE (2x DVB-S2X) (2x Xbox One USB tuners (1x DVB-C & 1x DVB-T2) (1x Nooelec NESDR Nano 2+ USB RTL-SDR tuner)
Octagon SF8008 (2x DVB-S2X)
Mut@nt HD51 (2x 2x DVB-S2X)
Triax TD110
Sky zone 1 minidish
Inverto Black Ultra Twin LNB
Alsat Superior Dark Motor
Onkyo TX-SR605
6x Bose Acoustimass/Lifestyle double speakers
Stone, Staffordshire
same i get every other transponder on 1.1m motorised dish in Sheffield, UK but not this one :(
