- Some SAT-related hardware.
- N-E from Riga
Made new feedarms and other connections for 1.8m CM. Original feedarms are 150cm and 115cm. I made new ones 145cm and 105cm but extendable.
my neighbors are lucky people, they this such a nice picture every time they look out of the window.
Reshuffled antennas little bit for better space usage. Installed new CM 1.2m (well, not really new but it has never been installed before) with nice sticker on it. View attachment 117551View attachment 117550
As I've said before, my neighbors are lucky people, they this such a nice picture every time they look out of the window. View attachment 117552
. They were programmed to modus5 in the shop and they are good to be cascaded. I suspect that my "new" switch is also programmed to same mode. But, if there are some problems I can always bring it to the shop for re-programming, and that will cost nothing or ~1 EUR.Lucky you to have somewhere that can reprogramme those switches - never heard of anywhere in the UK which can do that.@jeallen01 I use 4 such switches for about 10 years and happy with their performance . They were programmed to modus5 in the shop and they are good to be cascaded. I suspect that my "new" switch is also programmed to same mode. But, if there are some problems I can always bring it to the shop for re-programming, and that will cost nothing or ~1 EUR.
It is written there that programming can be done by PC card SS2 with installed ProgDVB and plugin S2DiSEqC. An example is given how to program the switch to Modus 6.you can do it yourself:
TBH, the one you circled looks like a twin, not a quad, as I can only see 2x F-connectors, or are there 2 more on the other side?Today I stopped by (yes, we still have not-online shops) satellite shop. Took picture of the LNBs they have. I was actually looking for quad Inverto LNB with small body, like that one I circled in red. I already got couple of such quads and I like them.
I understood what you meant. But I'm not English.Exactly, that is Twin but I need Quad, that is why I've said " like that one I circled in red ". My poor English.
and installed it on 4.6m Andrew and re-tuned antenna to Astra 2E @28.5*E
,of course my main aim is UK beam . Also some rewiring took place. Then installed several LNBs on some Channel Masters, they look more or less same as I am using same feedarm and LNB-holder design
. At the end of the day I wish to have system where 13 Quad LNBs, 3 Twins and 6 Single ones installed. Also 5x DiseqCs 1/10 and one DiseqC 1/4. All together there will be 9 Sat and 5 terrestrial tuners working at home. Also marinated ~4 kilos of meet for tomorrow's party (however it should be posted in grill thread)
I've got new LNB (well, actually LNB is old but feedhorn for it is new). View attachment 110589 With this combination getting good reception from Astra 2E @28.5*E. Some transponders are weaker some stronger View attachment 110590View attachment 110591 Will try to monitor signal longer period of time to see average 24h performance.
