Newbie Here 4K settop boxes
Archive-8
Thanks for the replies. It is looking like £211GBP for this box.
Which is the best firmware to add to this box?
Are there any alternatives around this price bracket that I should consider?
Do you mean the mutant?
If so I use openvix.
Xiaomi
SkyQ & Saorsat
NI
Yes - the mutant.
Are there any alternative boxes similar to it?
Dave5118
1.5m Gibertini with Inverto 5434 Unicable Hybrid LNB.
TBS 6903 with EBSPro
Vu+ Uno 4K SE
Edision OS Nino Pro
Starsat 2000HD Hyper
Sky Q Silver
Sky minidish with Sky Q Hybrid LNB
Nr Manchester UK
The Octagon sf4008 and the Gigablue quad 4k and UE 4k spring to mind.
Octagon are bringing out a successor to the sf4008, the sf5008, was supposed to be out at the end of April, but now saying June....... but could be even later, as they have not released any details as yet, despite promising they were imminent...... a month ago :rolleyes:
Xiaomi
SkyQ & Saorsat
NI
Is the S2X tuner something that should be purchased now or does it make much difference?
Archive-8
I paid to upgrade mine at the start. I also ordered the hdd separately and fitted it. That only saved me about a fiver so imho get wos to fit it.
Add a spare remote to your order, I paid a tenner for a spare as I can see me braking the remote.
Plus the lettering on the keys are starting to rub off.
It’s the best box I have ever got myself.
Xiaomi
SkyQ & Saorsat
NI
Is there an alternative remote for this device as I think I read elsewhere that the provided remote is a bit delicate.
Ghostleader
Glasgow,ish!
It's not "delicate" but if your a clumsy person and a laminate floor is in the equation also then I don't know, but the remote keys have not been resin stamped so the letters and numbers start to fade after a month or so because of the natural properties in human hands. The alternatives would be to wear nitrate gloves for the rest of your puff lol
MCelliotG
Thessaloniki, Greece
I'm really happy with my HD51, only if blindscan was released for the Silabs tuner....
Only a few channels in S2X so I have not botherd with this as for UHD 4K receivers the Amiko A4K combo takes a lot of beating @ under £100 with an Active Blind Scan :)
AMIKO A4K Combo
TJExcalibur
Out of this world.
Southern England
Looks good unfortunately I require PVR functionality.
I went for the Gigablue UHD Quad 4k. Have an SX2 tuner on order as part of BD present. I like the Quad 4k, good, well made solid receiver. I fitted a 3tb HDD and it works a treat. There are some good deals going besides Wos and fitting your own hdd gives you a choice of make etc.
Dave5118
Vu+ Uno 4K SE
Edision OS Nino Pro
Sky Q Silver
Nr Manchester UK
Do you have any ideas when the S2X tuners will be back in stock btw?
TJExcalibur
Out of this world.
Southern England
I ordered mine from SatKing Germany, unable to find any in the UK and its been dispatched.
Dave5118
Vu+ Uno 4K SE
Edision OS Nino Pro
Sky Q Silver
Nr Manchester UK
Oh right, I noticed WOS had some a while back, but appear to be out of stock now.
Xiaomi
SkyQ & Saorsat
NI
Thanks, but that is a bit out of my price range.
Was hoping for some alternatives cheaper than the Mutant.
Xiaomi
SkyQ & Saorsat
NI
Looks like SatKing.de is down for maintenance at the minute.
Dave5118
Vu+ Uno 4K SE
Edision OS Nino Pro
Sky Q Silver
Nr Manchester UK
Xiaomi
SkyQ & Saorsat
NI
Yip, you are correct. Not sure what happened there.
I am using a 1 terabyte hard drive with the A4K as I can continue watching live tv on my other equipment :)
Archive-8
I have a 1tb drive in my Mutant for pvr use.
I have it connected to plex as one of my network tuners along with my vu duo 1tb
