Listen Up Octagon SX88+
stephan94
Bavaria
To the question about reception of frequency 12722 H on 68,5East.
I am at the extreme limit to receive it with my antenna
In doing the test I noticed that the SX 88 is very sensitive.68°5E_12722_H-vert.jpg
Laser
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
World-of-Satellite
VU+ Ultimo 4K
GiGaBlue UHD Qaud 4K
GiGaBlue UHD UE 4K
VU+ Zero 4K
I would have expected these to be around the same price as the Edision, as they are pretty much the same thing in different boxes.
Yes, we've been negotiating with Octagon, price has been reduced to £49.00 :)
Laser
12543H on 5 West Multistream. I think the SR/FEC has changed again. Flysat says 36510 2/3 but no luck with that.
Any thoughts anyone? Thank you
TJExcalibur
Out of this world.
Southern England
I've got a TBS 5520SE, that will do it :)
So have I, stuck on the shelf. Plugged it in, looked at everything and thought, i can't be bothered. There it sits. When I get round to it i will sell it along with the other never used clutter here.
This applies to the Edision Primo too.
Having altered the parameters and rescanned, I can't get them either.
stephan94
Bavaria
this transponder is a test, currently there is no signal on this frequency. a1.jpg
Yes, there has been, but it has disappeared for now.
mike1
Non-28.2° Sat Specialist
Yorkshire Television
Triax 64cm triax ( Darkmotor ) Inverto Black Ultra.
T55 - 28E/19E/13E/1.9E
Mutant AX 51 Open PLi
GT Media V7SX
Just for the record ive got a Octogan SX88 using a Darkmotor& Triax 64cm. Reception of the Ukraine DVB-T multistream feeds from Sirius 4.8E works perfectly.
Reception of music channel M-1 via 4.8e was the main reason for the purchase. As the M1 on Amos 4w is pretty useless even with a black ultra and 88cm.
Noticed French and Italian channels on 5w but not of much interest.. 12.5w sometimes breaks up maybe dvb-sx is weaker? Noticed VH1, Paramount, Deejay all free on Itailian dvb-t!
Buggy box wouldn't recommend as a main receiver apart for multistream use!
Surprise it drives my dark motor with no issues!!!
Comes with a very cheap power brick always unplug when going out!! haha
Now i need to decide which E2 reciever to buy which drives a motor with multi-stream!!!
Martin88
Octagon SX88+ with
1m motorised dish
Gloucester, England
Stephan94,
Any chance of getting firmware V10466 - 09.06.2018 up on here?
Martin
mikeisyou
Feed Hunter
England
Stephan94,
Martin
If you have the previous version installed you will be prompted to update as long as you're connected to the internet.
Martin88
Octagon SX88+ with
1m motorised dish
Gloucester, England
I thought the version automatically downloaded was the FW version rather than SW version and therefore not as functionally rich. I have been in the habit of using the versions Stephan94 has been posting on here.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
From the Octagon-Germany EU site:-
suggest download it from the site.
Not tested by me yet so.........
Firmware Version V10466 - 09/06/2018
- SX88 & SX88+ Plus H.265 HEVC HD
Ins Hauptverzeichnis (USB Stick) entpacken.
- Aktualisierungen & Verbesserungen :
- Driver Upgrade:
- Audio mpeg124
- Video codec
- Record support from Ch List
- Programname character increased to 31 symbol
- E2 Settings supports improved
- Online Firmware Update add. additional function:
- Backup user data & Restore user data
- Polish Teletext improved
- Classic Men+ Icons added:
- Menu - Network: INFO (Vod) & OPTION (Operation)
- Android & Ios (Apple) RCU + WebIF .apk upgrade
- Stalker improved:
- https Support added
- Resolution to Infobar added
- Nashe TV improved:
- User Config support
- REC Icon for EPG archive added
- Timeshift EPG improved
- Menu button on EPG improved
- FAV Group problem fixed
stephan94
Bavaria
all correct:):)
feedme
Azbox Premium HD
dr.hd F15
180 prime, vbox and Motor , c-Band at the moment
110 offset With moteck sg2100 A
finland , , wesr
update url in sw is ******* , ?????
Is not connecting to anywhere . Or is it hidden ?
sentaro
120cm Astra@28.2°E - 100cm HB @13°E - 85cm Astra@19.2°E
Italy
dear sx88(+) users, as per this thread I know there were issues in recording the french multistreams (5W). Since the main reason for me to buy this product would be to be able to schedule recordings on those streams, could you update me about the issue? Has it been fixed by the latests fw updates? I would really appreciate your feedbacks. Many thanks :)
Pierangelo
150 cm from 80 east to 40 west + C lnb
Italy
If you use the command to change channel in the automatic recording section, it should work.
The problem, NOW, is no more the recording but the change of the channel in multistream.
ciao
