Listen Up Octagon SX88+
sentaro
120cm Astra@28.2°E - 100cm HB @13°E - 85cm Astra@19.2°E
Italy
If you use the command to change channel in the automatic recording section, it should work.
The problem, NOW, is no more the recording but the change of the channel in multistream.
ciao
Hi thx! But what is the tricky part? I mean, since I don't own the receiver yet, is it possible to manage the channel change (when setting the recording timer) by the user interface (i.e. remote control)? Or do you mean the channel cannot be changed while in viewing mode instead of timer setting?
Thanks again.
Pierangelo
150 cm from 80 east to 40 west + C lnb
Italy
using the recording timer is ok.
ciao
sentaro
Italy
Grazie Pierangelo.
do you also know whether it is possible to set (of course this applies to any channel) timers with different granularities such as one shot, daily and weekly and whether several timers can be stored (ie one to fire on Mon, another everyday at XX:XX, another one daily at YY:YY and so on).
Ciao :)
Pierangelo
Italy
more or less yes, but always before the change channel.
ciao
sentaro
Italy
mhh maybe it's better to postpone the purchase or to move to SF4008 (need to understand how the recording shedule is managed there...) :confused
stephan94
Bavaria
New SW 10468
Online and here
Download OCTAGON_SX88plus_SW_EU_V10468_140718.rar (60.55 MB) now. Fast and easy at workupload.com
- New Channel search function added:
- Menu - Installation - Antenna Settings: Search:
- Renew channels Data (TP)
- HDMI output Mode added:
- Menu - Settings - Audio/Video output settings:
- HDMI output: YCbCr444 / RGB
- Master Backup function added
- Dump firmware (full backup) function added:
- Menu - Backup & Recovery:
- Dump Software
- Dump SW it include all user data and configurations!
- Update to other box with these user data, change to sw name to "auto1.mupg"
- Radio background picture changed (Radio Button)
- QHD Stalker Support added
Laser
Is SX 88 going to be updated too?
stephan94
Bavaria
Today for the first time a feed was found with a PLS (as for the Multistreams)
the code and the PLS can be found after a long search with the PC here: Gold and 113344.
We thought that the Sx88 could find the MIS and the PLS because it was already in its database.
This feed is on the 16 ° East which has never had Multistream and this code PLS is quite new.
The SX88 found with the blindscan in MIS mode the frequency and the PLS.
a1-horz-vert.jpgSX88 PLS.jpgI am very pleasantly surprised.
Pierangelo
Italy
Dear,
Could You try spanish tdt?
Grazie
Ciao
EnoSat
enosat.euweb.cz
Slovakia
this PLS known from 2017 , feed on 33 East
and all PLS signals still lock only in Gold
stephan94
Bavaria
Thank you for this clarification EnoSat.
I did not know.
The PLS had already appeared since November 2017.
It was known, but by how many people?
This PLS is not indicated in any site like Flysat; Kingofsat, Satbeam etc...
I can deduce that the receiver found this value alone, without this PLS being in a database.
MCelliotG
Thessaloniki, Greece
What we have discovered considering PLS encryption is that there is only one PLS modus, all the others are derived from the Gold mode. So once you put a database with 200000+ codes you're good to go.... I believe this is also doable on PC programs but someone has to do it!
mikeisyou
Feed Hunter
England
Dear,
Grazie
Ciao
I can confirm Spanish TDT works but it will be available from the next update onwards.
DjbnpIcX0AMKhpY.jpg:large
Pierangelo
Italy
:-lmao
3 years ago I bought the original Televes sat tdt per more than 350 euro......
:-doh
MCelliotG
And this is officially the end of Abertis on non authorized receivers.... Let's now enjoy all the criers once the keys change for good, and don't expect Octagon to find them for you....
stephan94
Bavaria
Indeed, the pls code of this feed was found last year.It is used by the service provider Antennas from Romania.It is generally active in the morning/at noon.
Fortunately DM920 can also lock the signal with this code pls:
MCelliotG
