- Aug 10, 2008
- Romania
Yes but you cannot manually enter a satellite or certain codes because its E2, it's also very expensive as well
For E2 stuff I'm very happy with my Mutant HD51, I didn't think the DM 900 series was worth the extra money.
It is true that the dreambox is expensive,but the last DM920 UHD could be considered by those who want to have a receiver that knows everything.It's just as true that he is not thought of for a dxers,but the Silab tuner 2166D with which one of the 920 models is endowed,can give the same performance at the reception as other tuners mentioned at least on this topic,like:blindscan,s2x extension,mis/pls,low symbol rates,etc.
Here are some low symbol rates that the DM920 tuner has locked and memorized:
10.0E-12588 V,256,1/2;12609 V,256,1/2,12675 V,256,1/2
30.0W-11695 V,185,3/4,
23.5E-12640 V,477,1/2;12642 V,557,3/4;12646 V,280,7/8,
12.5W-12602 V,256,1/2,
42.0E-11555 H,405,5/6;11556 H,395,5/6;11557 H,410,5/6;11558 H,400,5/6,
16.0E-11070 H,334,1/2,11071 H,334,1/2,
11.0W-12621 V,256,1/2,etc,etc
DM920 UHD can also lock a difficult pls transponder,such as 11496 H, 7884,8/9,8PSK and also 11491 V,7522,8/9,8PSK:
16.0E-11070 H,334,12 & 11071 H,334,12__2018-07-13_23-59-23.png201.8 KB · Views: 18
Turksat_Low symbol rate_11557 H,410,56_2018-07-16_19-35-43.png117.8 KB · Views: 19
23.5E-12640 V,477,12;644 V,557,34;12646 V,285,78_12_2018-07-13_20-06-05.png285.7 KB · Views: 19
30.0W_11496 H,7884,89,8psk,PLS_ & 11491 V,7552,89,8PSK__2018-07-29_15-01-52.jpg72 KB · Views: 31
