Advice Needed ASTRA 28.2 PAN EUROPE beam
mirrors
starsat sr 4040 hd
Baghdad
hi
I live in Baghdad , Iraq and I want to receive pan europe beam of ASTRA 28.2
I know It's almost impossible
but need a detailed map of that beam footprint
or any other Ideas
even so I have to get a large dish antenna .. but need to know the exact dimensions and other technical stuffs or any other advices & tips
thanks to all of you
The new satellites have very steep signal strength drop offs at the edges of the beam. Its extremely unlikely you have any chance whatsoever of getting the Astra 2 signals - if for no other reason the adjacent very strong signals coming off Badr 26E will cause severe interference in your location.
What sized dish are you planning to use? What channels do you want? There may be easier satellites to get them off
So far out of the transmission area the only advice we can give you is:
Give it a try and good luck. And be aware any sensible hobby sized antenna is not going to be any use at all!
mirrors
starsat sr 4040 hd
Baghdad
thx Sir for detailed answer
now I have solid 190 cm prime focus dish antenna with regular LNB available here in the markets called ( Strong )
the dish was abandoned , I reinstalled it and fixed it focal length accuratly .
I could recevie some hard satellite to get here , such as NSS-6 95'E and the other one at 93.5' E
and many other satellites which are easy to catch
but still could'nt get ASTRA 28.2' E
planning to enlarge the dish antenna up to 260 cm or even 300 cm
thx for the advice
I was planning to enlarge dish , use LNB such as inverto with feedhorn
Mickha
North West
It would probably be better to go down the IPTV route, providing you have fast enough broadband, as 28.2E has 3 beams, according to lyngsat.
The UK spotbeam, which you will never get:
https://www.lyngsat.com/Astra-2E-2F-2G.html
http://www.lyngsat-maps.com/footprints/Astra-2E-UK.html
The Europe beam:
http://www.lyngsat-maps.com/footprints/Astra-2G-Europe-Ku.html
and the West Africa beam:
http://www.lyngsat-maps.com/footprints/Astra-2F-West-Africa.html
RimaNTSS
Some SAT-related hardware.
N-E from Riga
But do not go for mesh dish, that will not be good for Ku-band reception. Than I see you do not have so many chances to find solid dish bigger than 2.4m. Is there any chance you post some pictures of your current antenna? 1.9m is quite unusual size. Here in Europe 1.8m is more common.
The Europe beam:
There is also a Middle Eastern beam on one of the birds (2E?) - which doesnt seem to have been powered up as far as we are aware.
thx for the advice
1.9m will be far too small unless there is some exceedingly unlikely freak reception conditions. Even extending it Im sorry to say your chances are very remote. Not impossible though - a couple of Astra 2A transponders were reported in Yemen on a 2.4m dish a few years ago. 2A is no longer in service at 28E but it does illustrate odd things can happen.
Astra 28e received in Yemen
However unlikely it may be do keep on experimenting - you may get lucky at some point :) And should you manage some reception please do let us know - its the freak out of area reception that many of us love chasing!
mirrors
starsat sr 4040 hd
Baghdad
1 - of course mesh dish is out of plan
2- I can manage to get antenna dish at any size up to 6 meters diameter
3- I ll try sent photos of dish soon as I am far of home now for 2 weeks
I think in bagdad need more then 5 metter to get signal
