RS232 serial and STBtool
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
I have had a little go but didn't get any results as I don't really know what I'm doing.
I did find this video interesting:
Maybe I could spray some compressed air on my similar looking chip's when the box is on?
Freezer spray better than compressed air.
I see, that's what he's using. Accent threw me.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
@RustySpoons would you mind talking a look if I posted this to you, could you PM your details?
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Managed to flash the box over Serial.
All voltages present and correct from the PSU.
Is not a software issue. Removed tuner cans, tuner has faulty capacitors &/or 27MHz Crystal.
I did reflow the tuner IC and also removed the mainboard and reflowed the PCB tuner connections.
Will see if I can get a replacement Crystal from work or have another hunt about it in my component drawers, if that doesn't resolve it the tuner will need replacing as the SMD capacitors obviously are not marked and there is no schematic for this tuner/chipset so cannot replace them.
Video of firmware flash over Serial:
Video of Tuner fault:
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
I would like to thank @RustySpoons for his offer and effort he has put into this, something I wouldn't have been able to do. Hopefully a fix can be made.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Replaced the Crystal, fault is still present so it's either the capacitors (I've asked Serit for a schematic) or the Airoha AV2010 chipset.
I'm on the Hunt for a Serit SP720W, does anyone have a knackered D15 or know what other boxes used this tuner, like a D15 clone or whats inside the TM 5402 M3?
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Serit Tuner on it's way from Hong Kong, will update this when it arrives.
I am not sure but I think the Blade boxes were similar to the D15 and the TM-5402. I think I read somewhere on this forum that they were all made in the same factory?
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Tuner arrived from Serit this morning, removed/replaced old tuner, box is working perfectly :Y
Removed old tuner:20180908_103834.jpg
New Tuner Fitted:
And Test:
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
If anyone is wondering what the wet stuff is, it's flux remover as I always clean my work :)
Ref the flux remover, what would you suggest for general use?
(BTW, I have plenty of IPA already)
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
IPA is good, but takes some time. I use MG Chemicals flux remover spray but you have to be careful with it.
Thanks, I'll try IPA first but get some of the MG (or similar) stuff if I find it neccessary.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
IPA and a good stiff anti static brush will work just fine.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
I would like to thank @RustySpoons for all his effort into resolving my long running problem with this box. Top job.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
The box arrived today, works as it should, it's really a relief to change transponder and see a signal!
