moviestar 4k
Mickha
North West
Movistar is no longer on 30W, they stopped broadcasting any HD channels long ago, and finally stopped broadcasting all together, which did upset some subscribers, who couldn't get 19.2E, due to mountains.
They do have some channels that only broadcast using cable, and not satellite, but I should imagine they'll broadcast 4K football on 19.2E, althought they also broadcast on 61W:
https://www.lyngsat.com/packages/Movistar.html
Yes Mickha this subject has been covered elsewhere when I suggested that Spain may be served by just one satellite position I was shot down in flames when it was explained to me that the Mountain ranges in Spain are very high & what I had proposed was not possible :-rofl2
On the other side of the Mountain Ranges in Spain some cannot get 19.2 east & visa versa with 30 west :-doh
This is why they have to have 2 satellite positions 30W & 19.2E to cover the whole of Spain.
Mickha
North West
I thought Movistar left 30W, even though a few Spanish, SD, channels still remain.
The strange thing is that 30W does list Hispasat 4K 11262 V DVB-S2 HEVC/UHD 8PSK 3/4 30000, which has a Spanish audio track.
https://www.lyngsat.com/Hispasat-30W-4-30W-5.html
new stb 4k
Tururu
Assembled with recycled parts
Recycled as the owner.
Movistar+ emite en 4K eventos relevantes desde hace años por IPTV usando las TV 4K (UHD) que vendio.
Ahora la idea despues de 2 años de puebas es sacar canales IPTV en 4K (UHD) con emision continua.
Desde 2017 Hispasat se dejo de utilizar al terminar el contrato, si, es un problema no tener Hispasat, pero es lo que hay.
Llamando al telefono de informacion de Movistar+ (1004 desde españa), las operadoras informar que para mediados de 2019 (por estas fechas seguramente), tienen la idea de lanzar las emisiones 4K (UHD) en el satelite Astra a 19'2ºEste.
El nuevo receptor de Movistar+ 4K (UHD) Satelite/IPTV no esta listo, se retrasa la fase final, solo se comercializa la version IPTV 4K (UHD).
A los clientes de IPTV se les cambia el receptor IPTV HD por el nuevo, por oden de lista, si lo pides, puedes saltar la lista (+50€).
En su momento, ya lo intento en 2013 con emisiones, veremos que pasa dentro de 1 año.
En Astra no hay nada y en Hispasat tampoco hoy, mañana ni idea.
En Hispasat tenias unas demos de emisones 4K (UHD) desde hace años,
Hispasat 4K, HDR demo
El dia 8-9-2018 cerraron y arrancaron nuevas demos, similares a otras, estan en:
11262 V 30000 3/4 DVB-S2/8PSK MPEG-4/HEVC
Nuevo canal: Hispasat 4K HEVC, fin: Hispasat 4K.
Nuevo canal: Hispasat HD H264, fin: HDR demo
Movistar + issues in 4K relevant events for years over IPTV using the 4K TV (UHD) it sold.
Now the idea after 2 years of testing is to get IPTV chnnels in 4K (UHD) with continuous broadcast.
Since 2017 Hispasat stopped being used at the end of the contract, yes, it is a problem not to have Hispasat, but it is what there is.
Calling the Movistar + information phone (1004 from Spain), the operators inform that by mid 2019 (at this time, surely), they have the idea of launching 4K broadcasts (UHD) on the Astra satellite at 19'2º East.
The new receiver of Movistar+4K (UHD) Satelite/IPTV is not ready, the final phase is delayed, only the IPTV 4K (UHD) version is commercialized.
IPTV clients are changed the IPTV HD receiver by the new, by list ode, if you ask, you can skip the list (+50€).
At the time, I already tried in 2013 with emissions, we will see what happens within 1 year.
In Astra there is nothing and in Hispasat neither today, tomorrow nor idea.
In Hispasat you had demos of 4K broadcasts (UHD) for years,
On 8-9-2018 closed and started new demos, similar to others, are in:
11262 V 30000 3/4 DVB-S2 / 8PSK MPEG-4 / HEVC
New channel: Hispasat 4K HEVC, end: Hispasat 4K.
New channel: Hispasat HD H264, end: HDR demo
Tururu
Es una prueba de funcionamiento muy "interesante" para algunos, contada de forma sencilla.
Permite ver en un futuro cercano el mismo canal, en sus 2 versiones como ahora tenemos en TDT un canal SD y un canal HD, pero en satelite.
PQ esta prueba? podras usar un deco de satelite HD normal para ver estos canales.
Los canales HD van con codec H264, el Iplus de Movistar.+ perfecto, otras companias tambien podrian dar el "salto".
Para los lectores rapidos
, cualquier deco HD normal (de 50€uros) no tiene problemas para sintonizar/ver el canal.
El canal HD tiene 6Mbs de video/bitrate, el canal 4K (UHD) tiene 18Mbs de video/bitrate. (24Mbs si sumamos).
En un futuro cercano, y contando con los dedos (como siempre), podran meter 2 canales HD sin usar ningun calzador.
Si las pruebas en TDT2 que vi/medi, para 4K (UHD) las añado, quedaria asi el tp/frecuencia utilizada.
2 Canales HD con un BitRate de 3-4Mbs (no es de los peores que medi).
2 canales 4K (UHD) con un BitRate de 9-10Mbs
Con un tp/frecuencia de 48Mbs no hace falta que diga lo que pueden meter verdad.?
Esto ve un receptor SD/HD normal.
Si no tienes antena al Hispasat, te pierdes estos chistes, esta "cantado" donde apuntan las pruebas, el tiempo dira si tenia pilas la bola, los recortes no perdonan.
It is a very "interesting" performance test for some, told in a simple way.
It allows us to see the same channel in the near future, in its 2 versions as we now have an SD channel and an HD channel on DTT, but on satellite.
PQ this test? You can use a normal HD satellite deco to watch these channels.
The HD channels go with codec H264, the Iplus of Movistar. + Perfect, other companies could also give the "jump".
For fast readers, any normal HD deco (50 € uros) has no trouble tuning / watching the channel.
The HD channel has 6Mbs of video / bitrate, the 4K channel (UHD) has 18Mbs of video / bitrate. (24Mbs if we add).
In the near future, and counting on the fingers (as always), they could put 2 HD channels without using any shoehorn.
If the tests in TDT2 that I saw / medi, for 4K (UHD) I add them, it would be like that the tp / frequency used.
2 --HD channels with a BitRate of 3-4Mbs (it is not one of the worst ones).
2 --4K channels (UHD) with a BitRate of 9-10Mbs
With a tp / frequency of 48Mbs, I do not need to say what they can really put in.?
This sees a normal SD / HD receiver.
If you do not have antenna to Hispasat, you miss these jokes, this "sung" where the tests point, time will tell if you had the ball, the cuts do not forgive.
PD: Como siempre se admiten errores, de estos temas no tengo ni idea², pero no soy el unico, suerte.
Movistar + issues in 4K not use h265 ?
Tururu
Of course, a 4K receiver uses H265.
It is important to remember that currently Movistar + does not have 4K satellite receivers installed in the clients' homes.
It only has 4K IPTV receivers.
I comment the last tests 8-September-2018.
Surely it will be the future of the new satellite channels, so far 2, 4 channels all in H265.
Now one channel is on H265 and the other channel on H264.
The 2 channels have a very low bitrate.
The apparent warmth for our eye is very good.
In tests last year with Digital Terrestrial Televison channels, also on satellite, I could see channels with bitrate of 6Mbs-8Mbs and without problems with games and other scenes with very fast movements.
Before a 4K (UHD) channel could have a bitrate of 23Mbs, now with 6-8Mbs it looks perfect.
Now a tp / frequency allows to put many channels, the problem of the first broadcasts.
Apologies for the translation .
Por supuesto que un receptor 4K usa H265.
Es importante recordar que actualmente Movistar+ no tiene receptores 4K de satelite instalado en casa de los clientes.
Solo tiene receptores IPTV 4K.
Comento las ultimas pruebas 8-septiembre-2018.
Seguramente sera el futuro de los nuevos canales de satelite, hasta ahora 2, 4 canales todos en H265.
Ahora un canal esta en H265 y el otro canal en H264.
Los 2 canales tienen un bitrate muy bajo.
La calida aparente para nuestro ojo es muy buena.
En pruebas el año pasado con canales de Televison Digital Terrestre, tambien en satelite, pude ver canales con bitrate de 6Mbs-8Mbs y sin problemas con partidos y otras escenas con moviemientos muy rapidos.
Antes un canal 4K (UHD) podia tener un bitrate de 23Mbs, ahora con 6-8Mbs se ve perfecto.
Ahora un tp/frecuencia permite meter muchos canales, el problema de las primeras emisiones.
Disculpas por la traduccion.
the moviestar will be use also on astra 1 4k ?
Tururu
Movistar+ platform for satellite channels.
Currently, neither has nor had any channel broadcasting in 4K by any satellite.
IIn 2013 I made some tests and an end, never again, like Canal+ españa.
Movistar is not the same Movistar+
Movistar =/= Movistar+
Language, the great enemy of communication.:-doh
Movistar+ plataforma de canales por satelite.
Actualmente, ni tiene ni a tenido ningun canal emitiendo en 4K por ningun satelite.
En 2013 realizo unas pruebas y fin, nunca mas, como Canal+ españa.
Movistar, no es lo mismo Movistar+
El idioma, el gran enemigo de la comunicacion.:eek:
Tururu
Repetimos: Se estan cambiando los receptores de IPTV HD por los nuevos modelos 4K (UHD).
El orden para el cambio, segun lista clientes, puedes saltar el oden y pedir el cambio (+50€uros).
Tener como fuente/origen de una informacion la web SatCesc es como decir que este reloj roto da la hora bien.
Si, es cierto, 2 veces al dia.
Conozco al autor, suerte.
We repeat: IPTV HD receivers are being changed by the new 4K (UHD) models.
The order for the change, according to clients list, you can skip the ode and ask for the change (+50€uros).
Having the SatCesc website as source/origin of information is like saying that this broken clock gives the time well.
Yes, it's true, 2 times a day.
I know the author, luck.
