Who Are The Big Dish Men & Ultimate Dish Men ?
Thank you, the 4521 R signal is not listed on the two web sites often used by UK satellite enthusiasts (FlySat and Lyngsat)
Yes... here we did the updates daily :) :) :) there are a lot of sat-enthusiasts here.
Next vacation I'll test 40.5W to find more channels (4.5 ~4.8 band)
Yes.. tested 65W , but some friends show pictures with Viacom and some channels 4k (40.5W). Now, I don't have time to test 40.5W, but I have lnbf.
Here , I bought this lnbf (made here in Brazil): about 20 eur (105 R$)
LNBF AP30 PLL BANDA C MONOPONTO 4.5 ~ 4.8 Ghz - BRASILSAT -
There is a good way to do/make this kind of lnbf using some informations...
Hi Frank, very nice dish farm you have there with sizes that we can only dream about over here in the UK.
The link to the E-shop Satélite site has some very interesting extended C-band equipment on sale - i wonder if they would ship to the UK :)
Kingkad had a 3.8m Prodelin running well (:cool:) in Purley, but has downsized to a 1.2m Channel Master :-wow. He might get the original dish operational in the near future.
When I spoke to him a few weeks ago the Prodelin 3.8m dish had been dismantled, was in storage and up for sale. It was for this reason that I did not include the dish in the table. If he has plans to shelve the sale of the dish and have it re-installed I will add it to the table.
I have seller skype/whatsapp. Maybe he send to UK.
Ok thanks ..... I'm all ok for extended C-band reception but for what that lnbf in the link cost it might be tempting for others to dip their toes in the water so to speak. The poloriser barrel looks tempting as well :p
I missed the polariser barrel on their website, have you a link to the specific item. Prices look a lot more "friendly" than what we are used to in the UK:)
technical data (portuguese):
I don't have good english...
DADOS TÉCNICOS:
Entrada de RF
Freqüência de Operação
4500 ~ 4800 Mhz
Saída de RF (FI)
Freqüência de Saída 950 ~ 1250 MHz
Perda de retorno 10,0 dB (mín.)
Polarização Cruzada -25 dB (máx.)
Impedância 75 Ω
Conector de Saída Tipo F Fêmea
Oscilador Local
Freqüência do Oscilador Local 5,750 GHz
Estabilidade de Freqüência
± 0,057 MHz @ 25ºC
± 0,171 MHz @ -30 ~ +60ºC
Ruído de Fase
-73 dBc/Hz @ 1 kHz
-83 dBc/Hz @ 10 kHz
-93 dBc/Hz @ 100 kHz
Desempenho de Conversão
Ganho de Conversão 58 ~ 68 dB
Planicidade de ganho
±0,5 dB/27 MHz
±0,6 dB/36 MHz
±3,0 dB/banda
Ponto de Compressão 1 dB 0 dBm
Temperatura de Ruído 35 K
Espúrios na banda - 70 dBm (máx.)
Rejeição de Imagem 40 dB (mín.)
Requerimentos de Energia
Controle de Polarização
11,5 ~ 14,0 V (Pol. Vertical)
16,0 ~ 20,0 V (Pol. Horizontal)
Corrente de Trabalho < 130mA
Características Mecânicas
Altura 180 mm
Largura 160 mm
Peso 300 g
Tipo de Refletor Focal point f/D = 0,3 ~ 0,4
Temperatura ambiente
Armazenagem - 55° a + 80° C
Operacional - 30° a + 60° C
