Octagon slim optima oslo pll 40mm to c120
The latest bodge to come out of the workshop is this with very little choice with C120 LNB's these days...
Cut a C120 flange off a dead Inverto twin and grafted it to the Octagon which also had its integral feedhorn cut off the Octagon is PLL, so hoping for a bit of an improvement. RustySpoons gave me the idea...
If it is a PLL why are there two cavity traps with sealant over the screws ?
At some point there will be a shortage of C120 flanges, somebody should start an INOX production line........
I have been carving up a couple of OSLO LNBFs as of late, the internal chamber measurements leave a lot to be desired for full Ku band operation when compared to the theory measurements and some of the other designs on the market (Inverto and Sharp - DRO kit).
Then again I don't intend on using them for the satellites they were built for.
Well its advertised as PLL. They may be being cheapskates and using a DRO casing...
Will test it and see...
I would take the top off first to check, all part of the fun, and an essential to this forum.
Oooooerrr
Oooooerrr
No need, the bugger is DRO been on Octagons web site..looks like I might grafted the wrong one..The twin is PLL, sure that is in the box of bits in the garage...
That looks better
Trust
Nijmegen Netherlands
nowedays there are some cheap PLL lnb's for prices under € 3.- , look for Goobay
All they need to add is a C120 variant.
s-band
Essex
OSLO with 25MHz TCXO wart
OSLO, ext ref (behind LNB ), with skew adjust
Trust
