Just Sharing This Crazyscan Updates
CrazyCat
crazycat69.narod.ru
13E 4.8E 4W: Dish Variant CA-902 0.95m + 3xLNB Ku-Universal DreamSat DS8 + DiseqC 1.0
30W-95E: Dish Strong 0.95m + LNB Ku-Universal ALPS BSTE8-751B + Motor PowerTech DG240
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
SkyStar HD USB not supported.
Khartoum Sudan
SkyStar USB HD, Desktop computer, Windows 10, icore5
Khartoum Sudan
Thanks a lot CrazyCat for your fast response, but I guess I had seen in the forum that SkyStar PCIe type is supported. My Skystar USB HD belong to the same family, am I wrong?
See here if your device is supported by Crazyscan.
Khartoum Sudan
Khartoum Sudan
Hi satesco
I lookd in the link you sent , it has partial support as shown below
Partial supported satellite devices (RFScan,IQScan,SignalInfo feature)
STB0899 based
  • TT S2-3200 PCI, S2-3600/3650 USB2.0
  • Pinnacle PCTV 452e USB2.0
TDA10086 based
  • TT S-1401 PCI, S-2400 USB2.0
  • Technisat SkyStar USB2.0 Plus (TT S-2400 OEM)
  • Pinnacle PCTV 400e, 450e USB2.0
thanks a lot
please advice for the next step. what to do to let it work
Your HD version has a different demodulator chip, not compatible with Crazyscan.
I have the same device you have. Llew is right, Demod wouldn't support it.
Hi satesco
Unfortunately there is no further step... :(,because @Llew is right,demod has no support.I have the same device you have. That's why I haven't used it in years. Unfortunately,the manufacturer has abandoned...
Khartoum Sudan
Khartoum Sudan
Oppppps
Then I have to go to plan B, ie to buy new module.
Here your advise is required.I did some exercises I found ideas about the below TV cards
TBS5925
or
TBS5927
what is the one you advise, the one of the latest de-modulator options.
please mention if there are any other options.
Yours advises are appreciated
Oppppps
TBS5925
or
TBS5927
Thank you for trusting in my options for devices,but any well-intentioned advice is to be viewed critically, because its beneficiary is the one who pays.That's I recommend you read my review(#32) posted on the topic dedicated to TBS 5927.In fact to convince yourself that you made a good choice, you should read the whole topic.
I have both devices,5925 and 5927,but the latter is much better at the reception and is much more reliable than the first one.
I hope you don't regret your choice :Y
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Much faster at BS also ? Is there any chance I can connect to your 5927 with teamviewer ?
Of course it matters the search speed and locking the signal,but more importantly,from my point of view,is finding active transponders and the accuracy of the parameters found!I think that for dxer this should be the main criterion for choosing a tuner,the rest are secondary.
I don't know if it is necessary a meeting via TeamViewer to find out search time of 5925 and/or 5927.For that,Crazyscan help us,showing how long it took the search and the locking signal.
I did Blindscan tests with both devices on a satellite(at 90.0° E) that has both TV and data transponders.The search steps were the same for both, 2.6 MHz.
And here's the result:
tbs5925_10800-11700 H_2.6MHz-search & locked time=9.88 sec,
tbs5927_10800-11700 H_2.6MHz-search & locked time=3.40 sec.
Obviously tbs5927 is more powerful than 5925 to this chapter, but also in others.I don't know what else to prove!?!
