- Oct 21, 2006
- See signature
- North Somerset
1.2m CM with 1224 motor. It's in a bit of a state but should be easy enough to refurb.
Transparent ?
Had to be miles away from me didn't it!1.2m H to H satellite dish system | eBay
Find many great new & used options and get the best deals for 1.2m H to H satellite dish system at the best online prices at eBay! Free delivery for many products!www.ebay.co.uk
Worth a lot more than the £100 starting bid. Here is an opportunity to get a Jaeger 1224 at small money. That rust on the Jaeger 1224 will clean up easy enough, bit of elbow grease and a can of spray paint and that Jaeger could be up for sale for £300.
A friend bought a 1.2m Fibreglass dish recently (Not a CM), with a Key Electronics SP-5000 positioner box, never seen one before nor can I find any information about it.Not a dish but a classic single positioner box from Research Concepts. The RC1000A
RESEARCH CONCEPTS RC1KA RC1000A C BAND LARGE DISH SATELLITE ANTENNA CONTROLLER | eBay
Picture of your friend's dish could help.A friend bought a 1.2m Fibreglass dish recently (Not a CM)
Your friend is lucky, nice stuff.Pictures of Dish and Positioner, friend sent them before he started "restoring" it all.
@purplemarina is right, it is not only LNB-holder from Channel Master but also antenna is Channel Master And this is VSAT antenna, it has an offset angle something like 16-17*.
That's a Triumph Herald rear bumper I see in the first picture. Quite possibly a 12/50 in fact.
Well, it maybe Andrew (CM was overtaken by Andrew at some point of time). Look at those pictures (front and back), seems to me it is almost same antenna your friend just got. Feedarms connected to sides of the antenna and strength ribs more or less same. OK, I am not 100% sure but close to that.It doesn't look like a Channel Master to me, the rear structure is different, the LNB arms screw to the side of the dish, there is no mold stamp on the dish either. Also the actuator setup is a lot different to the CM ones I've seen. Do you have any information on the VSAT dishes?
