Best satellite dish 2019
S
Sleepingwiththefish
8 foot fence now fitted behind my pole ground mounted dishes to protect them from the wind :)
That looks weak. It would certainly fly away with wind gusts we get over here. The biggest problem is that fence breaking apart and start hammering the dishes making more damage than not having anything there.
The fence is fine there are several steel supports at the front & a old fence behind it,
I have added some wooden framework to the back & front,
It has withstood all the winds today as well :)
jaaa1976
vu uno 4k se, mutant hd51
Norfolk
OP Gibertini 100 XP+ Inverto Black Ultra 0.2
I think this is best suggested dish ... received answer also from other forums ... anybody can suggest good supplier buy this dish?
jaaa1976
Norfolk
I received today answer from german seller .... ( I think the best satellite dish is the Kathrein CAS 90 )
what you guys think about this dish ? .. its also more expensive.
sonnetpete
wordpress.com
Normandy, France
Personally, I think the Kathrein is overpriced. It's well constructed but not that much more than a Gibertini. However, I have no experience of that make. I do have a Gibertini and can vouch for it's constuction and durability...
It's also a 90cm diameter, but it is an equivalent gain at all frequencies. It also has a no quibble 2 year guarantee on everything.
Go for the 1m, unless you are fussy about size, and price.
Fisty McB
See my signature...
County Tyrone, N. Ireland
The cheaper of the two sellers (HM Sat Berlin) also has the same product on Amazon's UK site.
Actually bought some stuff through their Amazon.co.uk store a few weeks ago. Shipped to NI for £9 flat rate. No complaints especially as most GB based stores would charge at least that as a supplement for delivery here.
jaaa1976
Norfolk
Hello again..now am not too busy so going buy Gibertini or Katherein dish today ..but want ask if i keep inverto black ultra lnb in picture or buy new? I also have very weak signal now on 1 west UPC direct .. possibly lnb is starting be faulty? only few channels working.124981
Whoever installed it failed to pull down the rain cap on the connectors, you could have water in the cable.
And/or the dish is now very slightly out of alignment???
PS: it would be a good idea to seal up unused LNB input connectors.
PPS: If buying another LNB, why not get the Twin version, rather than the Quad version because the Twin should be cheaper, and is said to be slightly "better" than the Quad.
jaaa1976
Norfolk
Ok..understand..this can be problem .. i will install rain caps when new dish come .. need to find if keep this lnb or new? because VU uno 4K se have fbc tuner ..so i may need unicable lnb.
jaaa1976
Norfolk
Twin version lnb..yes its will be better because i have only 2 receivers in home.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
there is nothing to install.... rain cap is already there, you just need to pull it down from the body of the LNB. I am convinced there is nothing wrong with LNB, most likely antenna needs to be realigned.
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
LNB's are dirt cheap, might as well change it when you replace the dish.
jaaa1976
Norfolk
definetelly i will replace with twin version but need find which unicable lnb is best now
jaaa1976
Norfolk
Yes friend ..i just pull cap :Y
124982
but need to buy new dish .. arm already broken and this dish too heavy
124983
The broken arm has probably caused the LNB feedarm to droop slightly - and that is the likely cause of the misalignment of the LNB and the loss of signal strength.
jaaa1976
Norfolk
its working now better after i pull rain cap dawn... too much rain now .. so water also cause loose signal
RimaNTSS
N-E from Riga
"Dawn" did you mean at the morning time? :confused
If it was meant to be "down" than it can not change reception in any way. Perhaps when you pull down rain cup you changed position of the broken feedarm and that could change the reception.
