Advice Needed My humax ir-hd1000/me stop working
Khartoum Sudan
SkyStar USB HD, Desktop computer, Windows 10, icore5
Khartoum Sudan
Dears
Needs your help
My Humax IR-HD1000/ME
SW ver. MHZZSIR 1.00.05
is showing the below error message
BERR_FLASH_CRC(bE1)
please show me and how & where to update the flash
Be1 on most hardware equates to a corrupted firmware, you could try a hard reset which might fix it.
Were you updating the receiver or have you had a power outage ?
Khartoum Sudan
Khartoum Sudan
Thank you for replying.
Actually I had power outage. I was watching TV and the commercial power suddenly interrupted , then I received the error message in the screen (bE1).
would the hard rest fix it, if yes how to do it correctly.
Khartoum Sudan
Khartoum Sudan
Hi Dears Experts
Your contributions are highly requested in restoring Humax IR-HD1000/ME .
Any procedure to upload new flash firmware.
I appreciate any helps
Regards
Yasir Abuelhassan
You may well find the flash you require is no longer available. That doesnt appear to be a current model and manufacturers often drop support for stuff thats a few years old.
You could try contacting Humax Middle East explaining your problem & see if its available direct from them
This link might give you hope.
There is software for the 2000 floating about, but there is absolutely no guarantee this will fix your receiver.
Go on, you know you want to.
Khartoum Sudan
Khartoum Sudan
Thanks for your replying
Good advise.
Let it be the 2nd choice.
I had contacted technical support of Humax digital middle east. Lets see their answer. of course I will let you know.
Regards
Khartoum Sudan
Khartoum Sudan
Hi
Unfortunately the site in German. I couldn't do anything
Humax Middle east not answer yet.
This site is in English, mostly.
The idea was that there is hope with the firmware of the European machine, though you will have to accept the risk.
I'm almost certain it is available here , somewhere, with an intelligent search.
Khartoum Sudan
Khartoum Sudan
Hi Channel Hopper.
I failed to get an access to the site (http://colibri.de.ms/ ). I don't know why, may be I'm trying to access it from Sudan. Some sites are inaccessible. Any way I'm keeping trying. Wish me some luck
That is probably a removed site since the link was posted over twelve years back.
Search for the receiver model in the aboove box using Llew as a member, I think he had the Humax you might have success with.
Khartoum Sudan
Khartoum Sudan
Try this one. Colibri changed site address.
Hi
WOW. This is interesting,and it is good to work with the experts.
I found PR-HD1000 ,& I guess it is the German equivalent to IR-HD1000. If I'm correct which version of the firmware is suitable
My appreciation is continue.
I've removed your uploaded zip files Yasir, See Forum rules.
I can't advise on firmware at Colibri. I had an HDCI-2000, and firmware there is not compatible with that model.
Khartoum Sudan
Khartoum Sudan
Hi Llew
Ok I noticed the forum RULE.
But
HDCI-2000 is not available on the website you gave.
Hi Llew
But
Hi Yasir
That's why I can't help with your model. Although the hardware is similar, firmware differences mean any HDF files for the HD1000 series were not of use to the HDCI-2000, except maybe channel lists.
I didn't try any of those files in my (now scrapped) Humax for fear of corrupted data.
Anyway, good luck with your box.
Unfortunately as Ive already said thats an elderly receiver & at some point you will have to decide whether its worth carrying on chasing firmware for what is an obsolete receiver. Or just scrap it and buy a new one.
Khartoum Sudan
Khartoum Sudan
Hi Yasir
Any way thanks a lot for your help
Appreciated what done so far
There is not much else members can do, take a risk with software from another receiver, what harm can it do ?
