Top Tip T2-MI reception on E2 STB with SDG image - A complete step by step guide
You use Dreamedit or some other tool to edit it. It's all in this thread. It's really not clear what you're asking for.
nirvana
disk 150
italy
I just made a new config for 54.9E, working great!
Here's my new config in astra.conf
-- RTRS 54.9E
f12674rtrs0 = make_t2mi_decap({
        name = "12674V T2-MI  PLP0",
        input = "http://127.0.0.1:8001/1:0:1:320:3A2:0:225B182:0:0:0:", -- required
        plp = 0,
        pnr = 0,
        pid = 4096,
f12674rtrs1 = make_t2mi_decap({
        name = "12674V T2-MI  PLP1",
        plp = 1,
        pnr = 0,
        pid = 4096,
f12694rtrs0 = make_t2mi_decap({
        name = "12694V T2-MI  PLP0",
        input = "http://127.0.0.1:8001/1:0:1:320:3A2:0:225B196:0:0:0:", -- required
        plp = 0,
        pnr = 0,
        pid = 4096,
f12694rtrs1 = make_t2mi_decap({
        name = "12694V T2-MI  PLP1",
        plp = 1,
        pnr = 0,
        pid = 4096,
make_channel({
        name = "12674rtrs0 ", input = { "t2mi://f12674rtrs0", },
        output = { "http://0.0.0.0:9999/rtrs/12674plp0", },
make_channel({
        name = "12674rtrs1 ", input = { "t2mi://f12674rtrs1", },
        output = { "http://0.0.0.0:9999/rtrs/12674plp1", },
make_channel({
        name = "12694rtrs0 ", input = { "t2mi://f12694rtrs0", },
        output = { "http://0.0.0.0:9999/rtrs/12694plp0", },
make_channel({
        name = "12694rtrs1 ", input = { "t2mi://f12694rtrs1", },
        output = { "http://0.0.0.0:9999/rtrs/12694plp1", },
and the bouquet content
#NAME RTRS T2-MI (54.9E)
#SERVICE 1:64:16:0:0:0:0:0:0:0::---------- RTRS T2-MI (55E) ----------
#DESCRIPTION ---------- RTRN T2-MI (55E) ----------
#SERVICE 1:0:1:3F2:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:01 ПЕРВЫЙ КАНАЛ
#DESCRIPTION 01 ПЕРВЫЙ КАНАЛ
#SERVICE 1:0:1:3FC:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp1:02 РОССИЯ-1
#DESCRIPTION 02 РОССИЯ-1
#SERVICE 1:0:1:406:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:03 МАТЧ!
#DESCRIPTION 03 МАТЧ!
#SERVICE 1:0:1:410:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:04 НТВ
#DESCRIPTION 04 НТВ
#SERVICE 1:0:1:41A:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:05 ПЯТЫЙ КАНАЛ
#DESCRIPTION 05 ПЯТЫЙ КАНАЛ
#SERVICE 1:0:1:424:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:06 РОССИЯ-К
#DESCRIPTION 06 РОССИЯ-К
#SERVICE 1:0:1:42E:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp1:07 РОССИЯ-24
#DESCRIPTION 07 РОССИЯ-24
#SERVICE 1:0:1:438:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:08 КАРУСЕЛЬ
#DESCRIPTION 08 КАРУСЕЛЬ
#SERVICE 1:0:1:442:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp1:09 ОТР
#DESCRIPTION 09 ОТР
#SERVICE 1:0:1:44C:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:10 ТВ Центр
#DESCRIPTION 10 ТВ Центр
#SERVICE 1:0:1:7DA:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:11 РЕН ТВ
#DESCRIPTION 11 РЕН ТВ
#SERVICE 1:0:1:7E4:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:12 Спас
#DESCRIPTION 12 Спас
#SERVICE 1:0:1:7EE:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:13 СТС
#DESCRIPTION 13 СТС
#SERVICE 1:0:1:7F8:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:14 Домашний
#DESCRIPTION 14 Домашний
#SERVICE 1:0:1:802:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:15 ТВ3
#DESCRIPTION 15 ТВ3
#SERVICE 1:0:1:80C:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:16 Пятница
#DESCRIPTION 16 Пятница
#SERVICE 1:0:1:816:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:17 Звезда
#DESCRIPTION 17 Звезда
#SERVICE 1:0:1:820:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:18 МИР
#DESCRIPTION 18 МИР
#SERVICE 1:0:1:82A:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:19 ТНТ
#DESCRIPTION 19 ТНТ
#SERVICE 1:0:1:834:3196:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12694plp0:20 МУЗ ТВ
#DESCRIPTION 20 МУЗ ТВ
#SERVICE 1:0:2:456:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:ВЕСТИ ФМ
#DESCRIPTION ВЕСТИ ФМ
#SERVICE 1:0:2:460:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp0:МАЯК
#DESCRIPTION МАЯК
#SERVICE 1:0:2:46A:3182:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12674plp1:Радио России
#DESCRIPTION Радио России
i did everything in this tutorial, where did the discussion how to edit the lamedb?
nirvana
disk 150
italy
where is the discussion?
4Himdj
1.2 Laminas Dish
Rome
The general rules of the forum are that you have to make the effort yourself. You cant expect someone else to do the work for you Go through all the posts from the beginning again. With a bit of luck you will understand and get it working.
If you arent willing to put the effort in then you have to do without.
Thank you analoguesat
I've finally managed to let t2-mi work
but In the code mcgelliot posted for astra.conf and bouquet it seems there is no evidence of trasponder 12648 v (that it's the strongest one of the t2-mi)
I've tried to follow the scheme and add it on astra.conf, bouquet and lamedb but after this addition t2-mi stop to work. so i delete what i've wrote
do someone knows what to add only in astra.conf and bouquet?
thank you
best regards
MCelliotG
Thessaloniki, Greece
There is no evidence because I DO NOT receive this TP. Plus some work you need to do yourselves!
And I never described any way to edit the lamedb directly. I use Dreamboxedit exclusively for that. And this is exactly what my tutorial states, you scan the TP and edit the found data channel as a source channel. This is the easiest way to have a new source channel once it appears.
But.... when some people are only used to find everything ready, and the tutorial became somehow a work of someone else on different forums, anything is to be expected.
Honestly, I have deeply regretted my decision to help with T2-MI in the first place. Should have kept the solution to myself.... :angry:
Well I certainly appreciated your work and I still use your solution on my Mutant box.
4Himdj
1.2 Laminas Dish
Rome
I was misunderstood.
Your work is a milestone in satellite hobbist history
Without you maybe nobody can watch t2-mi
I did not criticize you
Best regards.
ciefp
68E-30W
Kisac
thank you
best regards
You can try my list. I added 12648 V according to the instructions from MCelliotG. I think that only that transponder without lame.db will not work for you. I advise you to try my settings.
f12648rtrs1 = make_t2mi_decap({
name = "12648V T2-MI PLP1",
input = "http://127.0.0.1:8001/1:0:1:320:3A2:0:225B168:0:0:0:", -- required
plp = 1,
pnr = 0,
pid = 4096,
make_channel({
name = "12648rtrs1 ", input = { "t2mi://f12648rtrs1", },
output = { "http://0.0.0.0:9999/rtrs/12648plp1", },
#SERVICE 1:64:167:0:0:0:0:0:0:0::-- 12648 V --
#DESCRIPTION -- 12648 V --
#SERVICE 1:0:1:3FC:3168:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12648plp1:02 РОССИЯ-1
#SERVICE 1:0:1:42E:3168:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12648plp1:07 РОССИЯ-24
#SERVICE 1:0:1:442:3168:225:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12648plp1:09 ОТР
#DESCRIPTION 09 ОТР
:: ciefpsettings E2 ::
..:: 12.05.2020 ::..
## Yamal 402 (54,9°E) ##
Update astra.conf - copy new conf to /etc ,755
add 12648 V
Thanks to MCelliotG
RTRS - T2MI streamrelay
12648 V - ok ( russia 1 scrambled )
12674 V - for me no signal
12694 V - ok all channels
  • ciefpsettings-enigma2-Abertis_30w-RTRS_T2mi_55E-12.05.2020.rar
4Himdj
1.2 Laminas Dish
Rome
thank you very much works perfectly!
nirvana
disk 150
italy
for the lameb speech how did you solve?
I told you a couple of weeks ago the info you want is on the forum. Use the search beacause no-one is going to do all the work for you. If you use the forum search & look up lamedb 8 pages of results come up - so ypou have a lot of reading to do.
If you cant be bothered to do the research then you do without.
nirvana
disk 150
italy
the question was not directed at you
4Himdj
1.2 Laminas Dish
Rome
good morning,
after I copied what ciefp have posted I've followed what is written on page 1 of this topic
I know it could seems hard, but after several attempts, it managed to work (it's also a satisfaction because all of this attemps makes me smarter in general with enigma2)
regards
nirvana
disk 150
italy
good morning,
regards
where the discussion of the lamedb in 1 page?
4Himdj
1.2 Laminas Dish
Rome
good morning
if I have not misunderstood you can modify lamedb in this way:
scan the t2-mi channel
import files to dreamboxedit
edit the channel as it's written on page 1
send the files back to the receiver
then if you choose a t2-mi channel from favourite folder of the settings posted, it works
best regards
ciefp
68E-30W
Kisac
..:: 16.06.2020 ::..
Update astra.conf
copy to /etc/astra/ and reboot
Update RTRS Krasnodarskij T2MI 54,9E
12674 v - signal is OK again
add 12714 v
ciefpsettings-enigma2-Abertis-RTRS t2mi 16.06.2020
  • ciefpsettings-enigma2-Abertis-RTRS t2mi 16.06.2020.rar
54.9E-T2-Mi atm:
12674 V-PLP 0 & PLP 1,
12694 V-PLP 0 & PLP 1,
12648 V-PLP 1
nttplpet
Thaicom
Thailand
I need astra.conf and the userbouquet.tv for frequencies 3655 L 15284 & 3635 L 15284 at 49E C-Band
Thanks for your help me.
Regards,
All information is already in this thread...
