Echostar ad-3000-ip firmware
daxv8
Visit site
Dreambox 7020 250g& Triax 90cm ,Technomate 8000 HD , Echostar AD-3000, Superjack VBOX2 Triax 1.1m LNB Lemon mono block
London
I am hoping someone has a copy of the Echostar ad-3000-ip firmware v900 or v901beta. I can only find version for the ad-3000-ipvia which is a different version.
I know I cannot go back to old 300 or 600 versions. Hoping someone still has a copy as Echostar is no longer around.
SimonE
Gloucestershire, UK
Hi daxv8,
I have checked my old PC and I have the following if its any help:- ad3000ipvcs_1000.zip and versions 804, 800 & 700. No sign of v.900 or 901 here.
If any of those are useful to you PM me and I'll email them to you.
SimonE
I think I have the 900 and 1000 versions here on the main PC if the 1100 is not to your liking.
daxv8
Visit site
London
Channel Hopper. If you can post the 900 version please I will try. The via versions seem to get mixed up and can junk the box if loaded.
The attachment from Llew is the non VIA version.
daxv8
Visit site
London
Thanks Channel Hopper will give it a go.
This one posted by Llew
The earlier ones - caveat emptor
  • ad3000ip_900.zip
  • ad3000ip_1000.zip
daxv8
Visit site
London
Got a bit further now. I go to upload displayed and it does a upload of the first two bars on the software being installed for 1 min then stops. I have seen people suggesting I need a bootstrap to be installed first before loading firmware?
Here's a bootstrap file. Heed CH's warning.
  • AD3000IP_Boot_OLD2OTA.zip
daxv8
Visit site
London
Thanks Llew,
I heed the warning but I am at cross way of what I do next. I know I started to get corruption of the channel listings and used to load the firmware to over come the issue some time ago. it now does not boot just giving me circles on the display after power up but it does except the upload command and starts off but the stops the transferr.As its only now used for the dish positioning it does not bother me. I though the boot strap might be corrupt but would that even allow me to get as far as I am with showing upload on the display? I cannot factory reset as it does not boot so catch 22.
I did read you were trying to JTAG through the processor and look at blowing the EEPROM which is an interesting option. I never sent it back for repair when Echostar were doing the chip replacements. They were a cracking box at the time.
Thanks Llew,
If it stops uploading a bin file part of the way through, that will certainly mean it has encountered a dead cell in the eeprom.
It's a nice box when it works OK, but now my faulty ones are only fit to be used for dish driving.
daxv8
Visit site
London
Tried the old bootstrap but unfortunately got "incorrect Header". Are there different versions of bootstrap available ?
The box was at version 900 before the problem occurred.
I managed to successfully do a upload and bin file size was 259kb. So some parts of the memory appear ok. I see the upload file sizes are all the same approx 1.5 meg.
didierdelaey
echostar ad3000ip
beigem belgium
hi,is existing some echoloader to sent before sending the *.bin file ?i cannot find anything to download.
the rs232 port of ad3000ip remain low -9V on RTS and RCV data so the port in not opening for file transfer!(should toogle positiv to enable transfer file)
is anyone to help ?
thank you
didier delaey
is anyone to help ?
thank you
didier delaey
Are you saying you have not got the Echoloader to transfer the bin files?
femi
Austria
Irte 2.4m (C-Ku-band), Laminas 1.8m (Ka-Ku-C-band), a lot of other small dishes, terrestrical antennas and receivers
Lower Austria
The name of the loader is "echoload2.exe", last firmware was AD3000IP_V1100_20040108_w.bin and have 1572928 byte.
Files with ~250kB are settings.
didierdelaey
echostar ad3000ip
beigem belgium
yes thank you for reply, i still looking for this echoload2.exe or .zip ,i cannot not found because all the link does not exist anymore or redirecty to a russian site.
thank you
didier delaey
thank you
didier delaey
This may be the one you need, bearing in mind I downloaded it from the Echostar site a long time ago as the 'new' loader.
  • echoloader.zip
didierdelaey
echostar ad3000ip
beigem belgium
thank you very much,th com port is definitively low -9v rcv and dtr low so impossible to upload the file, and replacing the U201 with a blank eeprom will not solve the problem, i cannot not program the u201 because I don't have the socket to insert it into the promblower
many thanks for all the info
didier delaey
didierdelaey
echostar ad3000ip
beigem belgium
hello from didier, i havethe file you want, mine ad3000ip us dead with the eprom U201 no hope to recover the box, because eprom must be preprommed before soldering a new one
thank you also to LLew for understanding my problem
best regards
xxxx.xxxxx EMail address redacted by Staff, for your protection and ours.
  • ad3000ip_1100.zip
