Tony Daly
- Jun 19, 2014
- Age
- 72
- 1.2mt motorised dish
- South West Ireland
The cable from the lnb goes into the GBOX. The output from the GBOX is then fed into the A-B switch. The two outputs from the A-B switch go to the SX88+ & the TM7102HD.Does the Technomate take it's primary feed from the cable that's looped through the GBOX or from the other input? Also try both feeds from the LNB on the Octagon.
It's entirely possible the Technomate has a more sensitive tuner, despite its age. You could try tuning both receivers to the same channel, then nudge the dish away from the peak and see which box loses signal first.
The TM had no problem locking the Radio channels on 45West but the SX88+ needed several attempts because the quality kept going up & down.
