- 80cm Motorised.
- North York Moors
Isnt Edision Primo and sx88 the same box under the hood?
Pretty much.
the search for all ALL IN ONE box continues, FOREVER!!! they all come close, but theres always something
is there a decent blind scanner 4K non E2 box out????
@Sat01Uk - thank you. i will do some research...I had the SX88 + and used to get the China Radio no problem, then upgraded to the SX88 4K and no luck on them. Also I did mention this before in another post, but was not able to get the Joy FM, Metro FM radio etc on Turksat, to the point I even emailed Lyngsat, it was tested and the radio is coming in loud and clear according to Lyngsat. These receivers seem to struggle with them low symbol rates. Am I missing the China stations?, no but as Manikm909 mentioned it’s more so I should get them but can’t. If older receivers can pick these things up why can’t the new ones!?
Well, in THAT case, your ARC is almost certainly "not optimum" (OR the azimuth setting for 45W needs a bit of "adjustment")@Sat01Uk - thank you. i will do some research...
well just an update, i just plugged in my SS88 *non 4k* version - found nothing, even though my other box is locked onto 45w - 11550 V 34288 - 11db
A further update - and not quite @jeallen01 ...Well, in THAT case, your ARC is almost certainly "not optimum" (OR the azimuth setting for 45W needs a bit of "adjustment"
Well, in THAT case, your ARC is almost certainly "not optimum" (OR the azimuth setting for 45W needs a bit of "adjustment")![]()
And then you should also be able to find IS8-1S, -2S, -4S & -5S (IIRC the channel names?) as I did for a total of 5x China Radio channels on that sat transponder - although there may not be live audio streams on everyone of those all the time (that's what I noted).A further update - and not quite @jeallen01 ...
I just took my Octagon SF8008 from the kitchen (spare box) plugged it in, did a blindscan and it found 3 TP's straight away - one of them is indeed - CHINA radio, i'm now wondering if the F connector on that particualr connection is "shot" (and its just co-incidence) - although that doesnt explain my main Edision MIO 4k STB not finding it - although looks like that might be an EDISION limitation now
I will do some more testing around 10pm (again on my SX88 and SX88 4K)
The best news for me is that channels "IS8-3S" etc are coming in at 16db !!! which is in line with my 20db on 34.5w and 12db on 58w and 63w
Yes, the SX88 found all 5 channels.yeah - they are all there - that was just an example.
the blind scan found the following: also just confirm, there is NO need to change from TV \ RADIO, they are automatically listed as TV channels after the scan, and play as audio as i would have expected - so nothing "weird" to do after a scan like i was led to believe
so just to confirm....your SX88 found them ok....? i will re-scan now...
thank youThe Octagon SF8008 uses a Silabs tuner and the Edision mio uses an Avialink tuner.
In tests I have carried out personally on low SR frequencies (SR1036) with very narrow bandwidth that are closely stacked together the SF8008 outperforms the mio.
The fact that the mio fails to lock China Radio and the SF8008 locks it seems to bear out the Silabs tuner is good for low SR narrow bandwidth frequencies and the Avialink tuner is not so good.
thank you
the annoying thing is, i actually relegated the Octagon SF8008 to the kitchen months ago after fitting a sky mini dish, for sat tv instead of freeview - and purchased the Edision (new) for pride of place in lounge as i thought that was a master feed hunter Oh the irony.
will do that now - although vix is on both octagon sf8008 and edision mio 4k - octagon wins as u say.I have used the Octagon SF8008, the Edision mio 4K and the Edision mio 4K+.
For me, those mios cannot compete with the Octagon SF8008 for low SR, narrow bandwidth frequencies, the Octagon wins hands down.
The other thing to remember is that different images on these receivers may also impact the blind scan functionality.
When I compared the mio to the SF8008 it was using a mio with OpenViX and an SF8008 with OpenATV.
A more accurate test would have been to use an idential image on the mio and the SF8008, possibly something to do in future?
GRRRR!Yes, the SX88 found all 5 channels.
Yes, you have to set the SX88 (etc.) to Radio mode to resolve and hear them (as I said "sometime" ago) - so, maybe, that could be where some E2 boxes "win out" in this respect.GRRRR!
i see the issue on these SX88 boxes, for me the channels flashed VERY quickly and disappeared, so it looks like nothing had scanned in, i did see them flash on the right hand side i.e RADIO....i then swtiched to Radio AND there they were - this is true for SX88
im going to try SX88 4K now...as i could have been fooled with this on that STB.
what a stupid system!!!
at least E2 lists them out after a scan, so you know that you have them, and you dont have to switch from TV\Radio.
thanks - i remember, but at that point, i thought you was advising of doing that with my E2 stb - I didnt "get" the correlation of doing that on the SX88.Yes, you have to set the SX88 (etc.) to Radio mode to resolve and hear them (as I said "sometime" ago) - so, maybe, that could be where some E2 boxes "win out" in this respect.
just tried OPENATV on EDISION 4K MIO - same result - it does receive the TP - 11550 V 34287 "BEAM_IS14__W01_0037" - but none of the RADIO stuff.I have used the Octagon SF8008, the Edision mio 4K and the Edision mio 4K+.
thanks !
.....and we have a winner!!!!! well done Octagon SF8008![]()
