Help Required Anyone know what polarmount this dish is off?.
well as long as you think my irte mount will work sweetly with my cm 1.8m then ye i,ve no problem in modding the declination on the mount.
Never been any doubt
Send some pictures and we'll assist.
butchyboy
channel master 1.8m motorised on c band,ku band,1.2 metre prime focus irte dish, 1.85cm offset mabo dish,vu+duo & 42 HD lcd tv
ireland
thanks very much hopper :) i won,t be starting the project till the weather gets some bit warmer over here in southeast ireland.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
With @butchyboy being in Ireland, I cannot imagine the package would be easy to transport.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
I was asked about the partial 1.8 mount that I have earlier in the thread.
OK, since he already has the IRTE polarmount, just some angle iron and a few bolts will be required to get the 1.8 up and runnng
butchyboy
ireland
hi hopper i sent you a message did you get it?.
Yes, but I'm travelling nowhere near Ireland.
butchyboy
ireland
Post your images of what you have, preferably on a new thread. There will be enough interest on how to best adapt the superior IRTE polar mount to work seamlessly with the 1.8 reflector.
