Advice Needed Oscillating signal strengths (5W transalpine)
astra19
98cm motorised technomate. 50e to 34.5w
Europe
Hi all,
Now that I have my Vu+ more or less set up the way I like it, I'm still struggling with the French multistream. The channels on 11509H come through perfectly most of the time, with 70%+ signal strength. I know that's not particularly meaningful, but it's helpful to compare between TPs on the same sat when I'm tuning at least. However, I can't for the life of me seem to lock 12648V. The strength changes between 60% and 0% multiple times a second, and it never stays around long enough to let me lock it. All the other TPs on the satellite are coming through completely fine. I don't have a DECT phone so I don't think that will be the source of interference.
Any ideas?
Scotland is out-of-footprint so you are doing well to receive what you are. It may simply be that you need a larger dish. I wonder if @Gladstones55 receives this transponder?
Try altering your USALS Longitude a tenth at a time. In North Yorkshire I get the same effect on that TP even if the alignment is just a tiny bit out and despite all other TPs blasting in.
astra19
Europe
Brilliant. I'll try that again. I know that by changing it a little I was able to get the first TP, though that went from 0 to perfect, so hopefully I can tweak it enough. Thanks!
Gladstones
Zone 2 Fixed @ Astra 2
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Working at the moment when get home let you know
Ive given up on 5W - the signal strengths are terrible now :(
antrabe
dreambox7080 dm900 viark droi
spain
From the south of Spain the strength its the same than always.
Really? They are massive here in t'Repooblic.
The Bolshie bugger from the "t'Repooblic". is unfortunately correct - apart from having lost the French channels some time ago, most of the remaining Itie ones are still very strong.
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Very poor reception here it’s dancing like a rockstar
sonnetpete
wordpress.com
Normandy, France
I realise that my input may be pointless, given that I'm on the southern border of Normandy, but 12648V is coming in at 100%Q
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Never mind you are only 700 miles from Midlothian
Would probably be ok if I could have a 1m dish pointing at 5W but its running an offset lnb on I think the 10E dish (1m). I only get the radio transponders now so a complete waste of time.
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Doesn’t matter not a fan of 5w a or b
Ah! I surmised you might have a touch of the Heath-Robinsons!
Adam792
Cheltenham
Seems like they’ve managed to make the signal drop-off pretty steeply on this beam from Northern England into Scotland.
The strength never really changed much here in Southern England, it’s a bit stronger than 5WA was if anything.
12648V is definitely slightly weaker than 11509H though (by a few fractions of a dB C/N). The high FEC makes them both need a very strong signal to lock though, I think on receivers with a percentage signal quality scale this can be extra confusing!
sonnetpete
wordpress.com
Normandy, France
astra19
Europe
Are you able to lock at all? I'm not too worried about this TP since the one that I do get has all the main channels, luckily. But it would be nice to get a bit more choice.
