South Tenerife
FOGGIE
Seatel controller
south Tenerife
Hello.
I am in South Tenerife. 20 mins South Playas de la Americas. I have a 3yr old SKY TV box. I look for decent instructions , best advised satelite frequencies too. To get more than 5 Uk Tv Channels here at home. I set my LNB to SKY NEWS. I only got 4 channels . Sky news, Pick, Pick+ and Sky Arts. There was x2 Virgin subscription channels too. I did chnage my default transponder frequency too.
Ant tips from you Frequency guys,,to get at least 10 Channels ?
any help appreciated.
Merry Christmas to all
What size dish do you have? You need something like a 3m+ dish to receive anything from the UK beam.
FOGGIE
Seatel controller
south Tenerife
Hey Jack
My dish , well the Ships dish not mine. Is 12 m. Its designed for ships. SeaTel 4004 Euro Quad LNB. This is controlled by a Seatel antenna controller. We have the Technology. But not the brains. I found a Sky news frequency all good. But only got 3 channels to watch. Due to Covid. we cant get a engineer out. Am hoping to find to Sat tech tricks/info on here. For best Satelite, Frequencies for our location. Any help very welcomed.
12 meters? Bloody hell - how big is the ship?!
SeaTel 4004 is a 40" dish (about 1m) according to Google. Can you adjust the LNB skew? The satellites at 28.2°E have an offset of around 7° counterclockwise when looking at the dish face from the front.
FOGGIE
Seatel controller
south Tenerife
Hey Ozumo..your absolutely right sir... Opticians for me i guess.
You have no chance of the 28E UK beam channels in Tenerife unless you use a VERY big dish as already mentioned. The best you are going to get is some of the news & entertainment channels on the European beams.
FOGGIE
Seatel controller
south Tenerife
Many thanks for your reply.
Still 28.2E ? Any frequencies ??
FOGGIE
Seatel controller
south Tenerife
I have got SKY news on 12070..
Any channels will do me
If you have any wwiss contacts you might want to try to get a Kabelio subscription over on the Hotbirds instead - they carry the main UK PSB channels encrypted on widebeams.
Cheers...will i get that on SKY TV receiver ?? Read a bit about default frequencies
You will get some of them. You should already have Pick & Pick+1 as thats on one of the frequencies you already have.
As you say the Sky receiver is from 3 years ago is it a Sky Q box? They require a different type of LNB and may be why you aren't receiving many channels.
FOGGIE
Seatel controller
south Tenerife
You reccomend changing the Freq to something else ?
FOGGIE
Seatel controller
south Tenerife
The LNB worked when we was in UK waters....many thanks for taking time out to help..will heed your advice in morning
FOGGIE
Seatel controller
south Tenerife
Hi . Offset
Offset 7 degrees ? is this the skew pole of LNB ?.. i have the skew pole -40 degree just now..This angle information taken from a marine V-SAT web site. I am not too sure if this angle is correct. I did notice the signal level go up slightly. I also could see a NID value, on my controller for the first time.
I have to enter the frequencies into antenna controller. DAC frequencies they are so called. . Small bit of maths needed with the Satelite frequencies.
What website are you getting the settings from? According to the manual default skew setting is 0030, I assume that is for zero degrees. POL OFFSET is the setting name, so for 7 degrees offset I think 0023 would be the correct value.
The Pick TV transponder is probably the strongest where you are, it is 12070 H 27500, enter that into the controller.
FOGGIE
Seatel controller
south Tenerife
FOGGIE
Seatel controller
south Tenerife
I am getting the frequencies of here. I just uploaded an image of my sky box settings & controller Skew settings.
As for the controller. I have to enter the Sat frequencies slightly different. As image shows..I can only enter 5 digits. This is called a DAC frequency. I am informed.
Yes, that's the TP frequency 12070 minus the LNB High Band Local Oscillator frequency of 10600, presenting 1470 to your decoder.
For low-band Transponders, the entry you need to make is the TP frequency minus the LNB Low Band Local Oscillator frequency of 9750.
The switchover between Low and High Band is around 11700 MHz, IIRC.
